IAT Sensor
Old Mar 5, 2011 | 06:13 PM
Eddy Teasdale's Avatar
Default IAT Sensor
I have a 1993, 940. When the outside temp is below 45-degrees (F), the car has a very hard time starting (but it will eventually start). If the outside temp is above 45- degrees (F), the car starts. Someone suggested I check the Intake Air Temp. sensor.
Any ideas on where that is located and how can I test it?
Old Mar 6, 2011 | 02:28 PM
lev's Avatar
lev
well, first make sure that the battery you have is good... the symptom you describe is indicative of just a weak battery more than the sensor. the sensor is located under the 3rd intake rail of the intake manifold, and is hard to get to without removing the manifold...
sabydady
Jul 7, 2009 04:58 PM
sRed70
Nov 18, 2008 09:18 PM
baggedb2200
Jun 26, 2008 08:41 PM
RandyTheHack
Jul 28, 2007 10:35 PM
jonbath
Jun 27, 2007 05:54 PM
