Idle adjustment
Old Sep 27, 2011 | 04:38 PM
brickrunner's Avatar
Default Idle adjustment
I would like to know how I can raise the idle on my 940? It is idling at 500 rpm's which is too lower. It is causing the car to idle rough. It use to idle at around 800, is that where it should be once I adjust it, thanks.
Old Sep 29, 2011 | 08:10 PM
Joseph/TX's Avatar
Idle doesn't normally need adjusting; computer is supposed to control it. I'd check out the I.A.C. (Idle Air Control) valve first..
Old Sep 29, 2011 | 08:26 PM
I will check and clean the IAC valve. One thing that I forgot to mention is that it only happens when the A/C is on. When the A/C is off it idles smooth and at 800 rpm's.
Old Oct 10, 2011 | 05:41 PM
I cleaned the I.A.C. valve and the throttle body and the low and rough idling has gone away. They did not appear to be too dirty when I looked at them before cleaning but apparently they were enough to cause problems. Joseph, thanks for the help.
dmg4
Jun 12, 2014 03:32 AM
nextproject
Nov 16, 2009 07:04 PM
litehwk356
Feb 12, 2009 10:33 PM
ss~zoso~ss
Jan 12, 2009 04:27 PM
Coho
Feb 5, 2007 12:40 AM
