Idle Problem
Old Nov 11, 2006 | 03:03 PM
SunnyCatStudio's Avatar
Default Idle Problem
I have an '82 240 GLT Wagon, w/ engine B21F-T.
The idle has been erratic lately, it sits at 1000 and dips down a little bit in a consistent rhythm, and the oil pressure gauge dips w/ it as well. What should I check?
It also seems like its going to bog out when the engine is cold, seems like the same problem but way more significant when the engine is cold.
Thanks.
Old Nov 11, 2006 | 03:14 PM
Default RE: Idle Problem
Is the tune up fresh?
Any vaccum leaks?
Old Nov 11, 2006 | 06:53 PM
it was tuned a month ago. I haven't checked for vacuum leaks yet. would a vacuum leak explain the oil pressure dipping too? that's what stumps me.
Old Nov 12, 2006 | 12:04 PM
The oil pressure dipping is due to the low Idle.
When the car idles low there will also be low oil pressure.
Old Nov 12, 2006 | 03:50 PM
cool, i'm off to check for vacuum leaks and maybe tune it up again
Old Nov 14, 2006 | 07:24 PM
cbevis's Avatar
check and clear your codes
Old Nov 15, 2006 | 10:09 AM
what do you mean "check and clear your codes"?
Old Nov 15, 2006 | 12:33 PM
cbevis's Avatar
Check out this link to "Check your codes" then "clear them" by troubleshooting the systems that might set off any given code. It sounds complicated but it isn't.
Old Nov 15, 2006 | 08:37 PM
it's an 82, no OBD.
Old Nov 16, 2006 | 11:25 AM
cbevis's Avatar
ah...you did mention that didn't you....
rosesforlily
Nov 5, 2009 09:23 AM
kevmcrae
Apr 25, 2009 11:25 PM
yank50
Mar 14, 2009 11:15 AM
ss~zoso~ss
Jan 12, 2009 04:27 PM
toshields
Dec 8, 2007 04:50 PM
