Ignition Key Won’t Turn
Old Sep 26, 2024 | 06:29 AM
mari's Avatar
Default Ignition Key Won’t Turn
Volvo 1986 245 ignition key won’t turn when in the off position and the steering wheel is unlocked. When it is tried and tried -turning it sometimes does catch and it will turn . If the key is left/kept in a 12 o clock position it will turn and start.
Any suggestions on how to deal with this issue? Can just the cylinder be replaced ? Will the key eventually not turn from the 12 o clock position? Is it a big job to replace/fix? Is it time to say goodbye? Any ideas, suggestions , all appreciated. Ty
Old Sep 26, 2024 | 08:50 AM
The tumbler can't be replaced by itself. If the steering column is unlocked - you can simply remove the ignition switch from the steering column lock and use a screwdriver (in the ignition switch) to turn on and start the car. If the column is locked and the key won't turn - you will have to remove the steering column lock from the column. Check this post for a couple of photos.
https://volvoforums.com/forum/volvo-...ed-out-116263/
maddis
Apr 24, 2024 09:33 AM
davidx1994
Jan 1, 2020 03:15 AM
MasS70
Sep 13, 2009 10:19 AM
lexusdave
Apr 21, 2009 07:56 PM
pbialk
Nov 3, 2007 05:26 PM
