Ignition problems
Old Sep 2, 2012 | 05:46 AM
yotamal's Avatar
Default Ignition problems
Hi everyone,
Just joined in...
I have a 97w 940 turbo which runs fine but has two problems which I suspect are connected:
1. When the engine is warm (and only then) it has problems starting and I need to pess down on the accelerator for a minute or so until the RPMs "stabilize" at ideling speed and stop droping to 0
2. On low speeds the car accelerated poorly until the turbo kicks in at > 2000 rpm. This is much better when the A/C is off
the entire air hosing is old and cracked but I haven't actually seen and air leaks or torn pipes.
Any suggestions as to what to try to fix first?
Thanks!
Yotam
Old Sep 2, 2012 | 09:14 AM
Hi and welcome to VolvoForums.
Cracks = leaks. Smoke it to make sure.
Old Sep 2, 2012 | 03:08 PM
lev's Avatar
lev
Fix any air leaks. Change the Fuel Pressure Regulator.
Old Sep 3, 2012 | 04:20 AM
yotamal's Avatar
Thanks!
Where do I find the fuel pressure regulator?
Yotam
dodgerkcj
Jul 2, 2018 11:41 AM
Ricardito
Aug 14, 2012 08:29 PM
roytoronto
Apr 26, 2009 10:59 AM
roytoronto
Apr 5, 2009 09:04 AM
