Inner Tie Rod Removal, Replacement, etc., etc., etc.,
Old May 27, 2016 | 10:33 AM
aznyaz's Avatar
Default Inner Tie Rod Removal, Replacement, etc., etc., etc.,
I just posted this in an existing thread but want to make sure it gets out there, so here it is again.
I'm about to start on inner and outer tierod replacement and was looking at the inner tierod and did not see any flat areas to get a wrench on to remove the tierod from the rack. Is this an original tierod from Volvo? I have determined that I have a CAM rack and also saw a post on another site that said you need to specify either a male or female thread.
Looking for a little insight on this matter.
Thanks.
MJ
Old May 27, 2016 | 02:48 PM
Nichals's Avatar
My replacements had flats cut into them so I removed the old round ones with a pipe wrench and installed the new ones like normal.
Old May 27, 2016 | 05:30 PM
aznyaz's Avatar
Thanks! A few more questions here. Are the originals peened in place, or is there a locking tab, or is it just good old torque and Locktite that keeps them in place?
I also saw where there are two different thread sizes available for the CAM rack: 14mm and 18mm. Is there some way of determining this before taking them off?
And one more: How do you counter torque the steering rack when loosening the tie rods?
Thanks again!
MJ
Old May 27, 2016 | 06:37 PM
Nichals's Avatar
No pins in mine, and it really wasn't enough force for me to feel the need to counter torque the rack. The ball joint ends should have flats however.
As for the size you will need to know the brand rack you have, also will want to pay attention to the lengths of the tie rods.
ipdusa.com has a great write-up about it, here is the bulk of it.
To determine whether you have a ZF rack or Cam rack most 240's had Service Plates (or labels) to designate the type of rack. 1978-79 the plate was on the door pillar. On 1980-93 the plate was on sheet metal between the grille and radiator (viewed by lifting the hood). Find the label of Steering gear (on the plate) and next to it will be a single digit code. 2, 4 & 5 indicate Cam racks, 3 indicates ZF rack.
Old May 28, 2016 | 10:49 AM
aznyaz's Avatar
OK, I'm still trying to make a firm determination as to what steering rack I have. Based on all research I've done, I have a CAM rack: the boot diameter where it attaches to the inner tie rod is roughly 3/8" (no plastic grommet to attach to) and all online research for my year point to a CAM rack. So, my final question is which CAM rack do I have? The one that receives 14mm or 18 mm threaded ball joint? I have looked for all possible locations of the fabled information plaque and there is none on my car. Will it just take removing the tie rod from the rack and measuring or is there another option?
One other question is, do I need to apply counter torque on the steering rack when loosening the tie rod? I have read 2 schools of thought and nothing that's conclusive.
Thanks again!
In search of info, MJ
Old Jun 6, 2016 | 08:11 AM
Jennie's Avatar
Please tell me how I can add a new question on this forum. Thank you Jennifer
Old Jun 7, 2016 | 08:37 AM
aznyaz's Avatar
If it's a response to this thread, there's a little black box to the upper left of the first post and to the lower left of the last post that says New Reply. Just click on that and start typing in the message box.
If you want to start a new thread just go to the top of the page to Forums, Volvo Vehicles, your particular model and look for the box that says New Thread either in the upper or lower left of the page. Just click on that and start typing in the message box.
MJ
Dead One
Feb 10, 2017 10:14 PM
pc142
Jun 3, 2011 07:45 AM
1988blue240
Apr 30, 2008 07:13 AM
1988blue240
Dec 7, 2007 06:06 PM
knight rider
Jun 9, 2005 08:45 PM
