Installing a new head unit ('93 940)
Old Jun 24, 2009 | 10:46 PM
LouEVille's Avatar
Default Installing a new head unit ('93 940)
Hi guys.
I don't consider myself a gearhead by any means, but I think I am competent enough to install a new head unit by myself.
I am, however, having trouble figuring out exactly how to go about it on a '93 940. Some places would have you believe that there is a wire harness that will work for this model, but I've read and heard from other places that I'll just have to solder the connections in. Is anyone here able to give me a definite answer?
Also, I am pretty sure I'll have to bypass the stock amp. Correct? Any suggestions?
Thanks for any help!
Old Jun 25, 2009 | 12:42 PM
TIPSP's Avatar
Got Boost?
if there is an adapter out there, then why not just do that.
It is fairly simple job. YOu look at the maual match the colored wires and find a way to connect them. then enjoy the new unit.
Old Jun 25, 2009 | 01:00 PM
Desert S60 T5's Avatar
I agree... I have installed a number of new head units in my past cars, and sometimes its as easy as using a harness. If you have to solder the wires yourself, just make sure you follow the color coding and you will be good to go!
Old Jun 25, 2009 | 03:27 PM
LouEVille's Avatar
Thanks for the responses.
I'm just having a whale of a time finding a wire harness that actually fits around my locale. I may have to go with Crutchfield, although I'm not convinced that what they have will work either. I guess it's worth a shot though.
Old Jul 2, 2009 | 06:22 AM
anotherskait@yahoo.com's Avatar
Any luck finding a harness? I`ll be doing this on my `91 940 soon.
Old Jul 3, 2009 | 03:16 PM
LouEVille's Avatar
crutchfield.com is your friend. Still haven't installed the unit yet as I just haven't had enough time to dedicate to the project. The hardest part is going to be the wiring/bypassing the stock amp that's under the steering column, but it shouldn't be too tough of a task.
btmyers
Aug 15, 2020 02:09 AM
chill91
Nov 20, 2011 12:04 AM
BamaMac54
Sep 27, 2011 11:25 PM
redbandit850
Jul 13, 2007 02:18 PM
Nand12
Oct 23, 2005 02:36 AM
