Intank pump on 2 pump system!
Old Nov 22, 2019 | 12:35 PM
Goldenblock's Avatar
Default Intank pump on 2 pump system!
Quick question. Had my 740 for almost 15 years and over 2 million miles( no misprint)!!!
Know absoutely everything about them besides this???
if your intank pump is dead like mine... How and where does the gasoline make its way to main pump/ injectors????
Where in the sender unit does it travel through???
Thanks fellas
Old Nov 22, 2019 | 01:41 PM
it flows through the dead transfer pump. your main pump has to work much harder, and when your gas tank is much below about 1/3rd full, you may experience fuel starvation at high acceleration.
Old Nov 22, 2019 | 05:46 PM
Default Pump
I never experienced that never. I purposely pulled intank pump at low low fuel levels many times.
absoutely no difference in performance or sound.
I do have a regina 1989 non turbo dual fuel pump system.
just putting that out there. I don't believe it travels through a dead fuel pump but rather the hole on the bottom might be wrong.
anyways ive never changed it and have well over 2 million miles. No misprint!! In my car it appears irrelevant at this point.
Peace brothas
Old Nov 22, 2019 | 06:39 PM
silvermine's Avatar
where did you go .. to the moon and back a few times? lol seriously though i have no idea whether my in tank pump works or not all i know is
my 240 starts runs and gets from a to b every time in all weather .. so far...
Old Nov 23, 2019 | 07:24 AM
jagtoes's Avatar
Peace brothas
Sorry you just broke the BS meter on the mileage statement.
If you do have a 2 pump Regina system which is rare and the intank pump is bad then you get the conditions that were stated above. If you think you have a 2 pump system then pull the in tank pump and test it. Come back and tell us your results.
Old Nov 23, 2019 | 07:33 AM
Default Pump
Nobody believes my miles so im not sweating that.It is a regina 2 pump system!! No need to pull intank. ive pulled the fuse piles of times well into the red range and it had no effect on performance or no sound changes.
i believe the 1/3 tank info doesnt apply to my car.
and having a 2 pump system on my regina car is rare. I ve personally never seen another.
ive gotten numerous offers to sell it but no way Jose.
Old Nov 23, 2019 | 12:36 PM
are you sure pulling fuse 11 is disabling the in-tank pump? its quite possible its not, your car is something of a muddle so its wiring may be weird, too.
shut the ignition off, remove fuse 1 and fuse 11. take a foot or so of some thin gauge solid copper wire, like AWG 22 or 24, strip about 3/4" from each end, and run this jumper wire from the bottom of fuse 1's socket (which is always hot) to the top of fuse 11's socket, this should power just the in tank pump, if you remove the gas cap, you should be able to hear it humming with your ear against the filler pipe, its easier if the fuel level is relatively low.
now move that jumper to the bottom side of the fuse 11 socket, and you should hear only the main pump run. when done, remove this jumper, and replace the fuses, 25A in fuse 1, 15A in fuse 11.
2 million miles in 30 years is 66000 miles/year, 1300 miles/week, or an average of 180 miles every single day with no downtime. assuming the vast majority of those miles are highway miles at 100km/h (60 MPH) average speed, you have spent 22 hours/week, every single week for 30 years, in the seat of your car. you've had to change your timing belt every year, oil about monthly. you are probably on your 30ths or 40th set of tires
Old Nov 23, 2019 | 01:14 PM
Default Pump
Thanks for info brotha P!! Your calculations are close to right. Didnt go through that many tires though.
i checked what you said.... Another question. If you remove fuse to sender unit... Shouldnt the gauge not read fuel level????
thankyou young man
Old Nov 23, 2019 | 01:22 PM
the fuel sender is completely independent from the fuel pump. the sender is a variable resistor thats wired up to the fuel gauge, and isn't directly powered. the gauge does provide some small power to it, which comes off the general instrument panel power circuits, and the gauge displays the current passing through the sender, which is proportional to the resistance per Ohm's Law....
Old Nov 23, 2019 | 02:14 PM
Default Pump
Even if i disconnect sender unit connector, it still gives a reading on Gas gauge. And no effect on performance or noise level increase.
peace brothas
Old Nov 23, 2019 | 02:30 PM
wow, your car is like magic. the gas gauge works without being connected, and the in tank pump isn't doing anything yet the main pump isn't ever making noise.
Old Nov 23, 2019 | 05:40 PM
jagtoes's Avatar
He said he only owned the car for the last 15 years so this would peg the BS meter.
Old Nov 23, 2019 | 06:13 PM
lev's Avatar
lev
Not his first time either...
Old Nov 23, 2019 | 06:44 PM
Default Pump
Yall must be a little slow or something???? I had the car for 15 years. I'm not the original owner!!! You Dont know the previous mileage....
Its not something i broadcast like that guy with the p1800.
mileage is nothing to these cars. There is no reason to make up stuff.
my original question was pertaining to intank pumps.
Yall don't run the forum!! Half the time your information is self pleasing and innaccurate!!
peace
Old Nov 24, 2019 | 05:17 AM
dytha99's Avatar
I've seen the elusive two pump Regina myself and it was discussed (with pics) on this very forum!!!
https://volvoforums.com/forum/volvo-...s-bosch-86945/
The under car main fuel pump that is pictured currently resides on my '92 240.
The in tank pump that is pictured is still in my basement.
Old Nov 24, 2019 | 02:40 PM
lev's Avatar
lev
peace
I think the mileage argument can be solved easily enough with a Carfax check. Just list the VIN and we'll see...
Old Nov 27, 2019 | 12:35 PM
  #17
dorvin's Avatar
I'm curious to see some pictures of this 2 million mile 740.
Old Nov 27, 2019 | 04:59 PM
  #18
Default Pump
Sure. Its not a big thing no body believes it anyway.
ive been thru several odometers.
Happy holidays fellas
Old Nov 28, 2019 | 10:09 AM
  #19
lev's Avatar
lev
That makes sense since the odometers go only as high as 999,999 miles. Once you reach that, I believe they self destruct, right?
Old Nov 28, 2019 | 12:10 PM
  #20
nah, they go through a wormhole in the spacetime continuum, and reset back to zero, making it a brand new car all over again!
akpasta
Jun 26, 2017 02:34 PM
floz313
Oct 27, 2014 07:59 PM
96850urbo
Oct 29, 2010 06:17 AM
qstyle
Aug 24, 2009 07:32 PM
freelancewagner
Nov 11, 2007 08:59 PM
