intermediate shaft wows
Old Apr 12, 2010 | 05:41 AM
Kaspir's Avatar
Unhappy intermediate shaft wows
I have a manual 81 240dl just the other day the car died at a stop light, my wiffe was driving so not sure what sounds it made if any. checked for fuel supply and the mechanical pump isnt delivering, pulled the pump and it's fine(still pumps when dun by hand) had some one crank it over while i watched inside the slot, it appears that the intermediate shaft is not spinning. where do i start
Old Apr 12, 2010 | 10:13 AM
Les Vegas's Avatar
have you checked that the timing belt is turning ?
Old Apr 17, 2010 | 06:48 AM
Kaspir's Avatar
is a broken timing belt.... man the fan is hard to get off
Old Apr 17, 2010 | 10:19 AM
Les Vegas's Avatar
shouldn't be too hard
maybe you should have left the belts on till you got the nuts loose?
Old Apr 21, 2010 | 09:26 PM
Kaspir's Avatar
fan wasnt a big deal., have got cam lined up with marks and distrubator at #1, now how do i tell where the crank is? are the any alingment marks in the casting i havent seen
Old Apr 21, 2010 | 10:00 PM
swiftjustice44's Avatar
Cam, intermediate shaft and crank ALL must be aligned...all three marks are rather easy to see if you know where to look.
Old Apr 25, 2010 | 08:12 AM
Kaspir's Avatar
thanks for the picture that makes it alot easier
Old Apr 26, 2010 | 09:05 AM
Les Vegas's Avatar
just wondering
how does a person know
if the # 1 is TDC on compression stroke,
other than chance being 180 deg out ?
do you have to take the valve cover off,
or can you peek in thru the oil fill ?
Old Apr 27, 2010 | 06:34 AM
act1292's Avatar
I always position it prior to taking off the crankshaft pulley and the lower timing belt cover. There is a mark on the pully that you align with a mark on the timing belt cover. I believe the mark on the cover is marked 0 deg TDC.
Old Apr 27, 2010 | 08:51 AM
Les Vegas's Avatar
Originally Posted by Les Vegas
just wondering
ok
after thinking more about it
if the camshaft pulley has its mark lined up
then it is on compression for # 1,
and if the rotor is pointing a # 1,
and the mark on the intermediate pulley is lined up,
then you just have to bring # 1 piston to TDC
by lining up the mark on the crankshaft pulley,
and all should be well.
Have a good one.
Les
Old May 8, 2010 | 05:39 AM
Kaspir's Avatar
quik question? the picture above is that for a 240 with a b21a
Old May 8, 2010 | 10:48 PM
B21, B23, B230...they're all the same.
Joey_mck14
Mar 30, 2014 08:19 PM
TEK 242
Mar 26, 2013 06:31 AM
Gashog
Jan 26, 2013 04:49 PM
woodenyouknowit
Feb 20, 2012 10:08 PM
Volvo-Profess
Jan 14, 2011 05:55 PM
