Intermittent and auxiliary gear placement
Old Apr 5, 2023 | 12:15 AM
dafuzzydude's Avatar
Default Intermittent and auxiliary gear placement
I recently replaced my timing belt and my front seals, and forgot to label my gears. Are the gears different size? Also, which one does the washer go behind?
My timing belt skipped 2 teeth, and isn’t starting anymore, so I’m hoping this was the issue. It didn’t feel very tight when I pulled on it, so maybe I need to replace the tensioner and spring?
Old Apr 11, 2023 | 06:55 AM
admasters's Avatar
This all depends on your engine. You might be referring to the timing gear and the balance shaft/distributor drive gear. I believe they are the same size. Depending on the vintage of your engine, the washer should go behind the timing gear, later engines don't seem to need them. Recheck your tensioner, it needs to be pressed flush against the block and if you're not careful, it will not seat fully and begin to walk the timing belt off the gears.
The B230 is a non-interference engine, but you may have slipped more than 2 teeth somewhere, especially if you have a side-mounted distributor (I don't have that).
Corrections to this post welcomed.
adamwithwood
Jul 17, 2011 11:33 AM
tompowers85
Penta
Jun 13, 2011 12:51 AM
crocker
Dec 2, 2010 09:31 PM
dhansen
Mar 27, 2008 06:39 PM
jamescambron
May 22, 2005 09:17 PM
