Timing Belt Trouble!!
Old Nov 30, 2010 | 12:17 PM
crocker's Avatar
Default Timing Belt Trouble!!
Ok so I was workin with my 2000 S80 doing a timing belt replacement. I got the cam gears lined up and the crank gear lined up before I got the belt off. While I was working the crank gear spun and now I have no clue what to do! I know if I dont get the timing right my motor is screwed!! Please help with this issue! thanks!
Old Nov 30, 2010 | 03:53 PM
75ohm's Avatar
How much did it spin and in what direction? If lined up, how far off is it?
Old Nov 30, 2010 | 03:54 PM
75ohm's Avatar
To clarify, if lined up correctly for the timing marks, how far off that mark is it now?
Old Nov 30, 2010 | 04:57 PM
crocker's Avatar
not really sure how far it spun but we found a ridge on the front of the gear right behind the balancer. we have that lined up now. is that how its supposed to line up. the cam gears are still lined up
Old Nov 30, 2010 | 05:53 PM
dsharp's Avatar
Here are some pics from my S60. Not sure they are the same.
Attached Thumbnails Timing Belt Trouble!!-timing-mark.jpg   Timing Belt Trouble!!-timing-mark-2.jpg
Old Nov 30, 2010 | 07:12 PM
ed7's Avatar
ed7
The sprocket only fits the shaft one way. One master spline, many smaller splines.
Ed
Old Dec 2, 2010 | 03:10 PM
crocker's Avatar
Default Lined up no start
We have the marks lined up on both the crankshaft and the camshaft as stated and pictured ( http://volvospeed.com/Repair/s40_timing_belt.html ), but when we try to start the vehicle it will not start - just turns over. Any suggestions?
Old Dec 2, 2010 | 06:05 PM
dsharp's Avatar
Default timing belt
Does either cam have variable valve timing?
Old Dec 2, 2010 | 08:48 PM
crocker's Avatar
im not sure if they do or dont. there isnt anything that shows if they do have vvt. how would that affect the alignment of the marks?
Old Dec 2, 2010 | 09:10 PM
dsharp's Avatar
You have to hold the cam and rotate the vvt before you put the belt on. If you don't the cam will be too far advanced.
Old Dec 2, 2010 | 09:15 PM
dsharp's Avatar
I just realized you are working on a s80. I'm not sure it's built the same as the 2.3 in the s60. I want to say that the s40 vvt stays locked when you remove the timing belt.
Old Dec 2, 2010 | 09:31 PM
dsharp's Avatar
https://volvoforums.com/forum/volvo-s80-18/75ohms-2000-s80-timing-belt-replacement-instructions-18853/ Not sure how to insert a link. This was a s80 timing belt post by 75ohm that may help you
urbanfinch
Jan 4, 2015 11:38 PM
kidsgone
Jan 24, 2011 08:17 PM
bcon415
Sep 19, 2008 07:17 PM
Soloracer
Aug 26, 2006 04:43 PM
Qamar
Aug 24, 2005 07:37 PM
