ISO Volvo 240 Engine Crossmember
Old Jul 21, 2019 | 10:33 AM
RA022226's Avatar
Banned
Default ISO Volvo 240 Engine Crossmember
Had a little accident while off-roading the 240 and have damaged the engine cross-member passed what I can repair. Also did some decent damage to the passenger control arm but have sourced a replacement.
Old Jul 22, 2019 | 07:20 AM
act1292's Avatar
What cross-member are you looking for? The one that holds the rear of the transmission or the one underneath the engine? The transmission cross-member is readily available from Volvo. Not so sure about the one under the engine. To replace the engine cross-member requires quite a bit of work.
Old Jul 22, 2019 | 01:38 PM
RA022226's Avatar
Banned
Unfortunately I need the one under the engine that the steering rack mounts to.
Old Jul 22, 2019 | 03:20 PM
probably crossmember 1304668
and yeah, looks like its welded to the inner wheel housing pieces, and lotsa work to remove from a car
part #15 in this diagram:
https://www.volvopartswebstore.com/i...e/GR-67971.jpg
supposedly available from Volvo for $80-100.
https://www.volvopartswebstore.com/p...5/1304668.html
Old Jul 22, 2019 | 11:59 PM
lev's Avatar
lev
I seriously doubt an OEM Volvo crossmember would be anywhere near $80, or that it'd be available.
Old Jul 23, 2019 | 12:24 AM
dunno, volvopartswebstore is a dealer, they claim its still in the catalogs. the acid test would be to order it, if its unobtanium, they would mark it NLA going forward.
Old Jul 23, 2019 | 06:11 AM
act1292's Avatar
I believe the part he is referring to is item #1 in this diagram:
https://www.volvopartswebstore.com/s...rimLevel=28242
However, the parts listing below the image doesn't show #1. I suspect it is NLA.
The part that Pierce quoted is the support that the radiator sits in.
Goldenrod1990
Jul 9, 2016 10:55 PM
analogies
Mar 29, 2013 01:56 AM
joshofalltrades
Mar 12, 2012 01:49 AM
Tommyb50
Mar 6, 2010 10:35 AM
78vovlo244
Feb 25, 2009 04:06 AM
