just bought 1983 245 dl, b23f, m26
Old Dec 4, 2011 | 06:30 PM
tdrendel's Avatar
Default just bought 1983 245 dl, b23f, m26
89000 miles any thoughts? any advice? i love the car i want i to run for a long time
Old Dec 4, 2011 | 10:56 PM
brickrunner's Avatar
Very low milage for an 83 and those red block engines are very durable. The important thing is to not overheat them and keep the cooling system in top working order, it is even more important than the oil changes. I recommend conventional Rotella 15w 40 oil and changing it every 5,000 miles. Another thing that I recommend is that you check fluid levels and visually inspect the engine bay every week or month, depending on how much you use the car. I have found a leaking radiator hose, leaking fuel hose, and loose alternator belt thanks to those brief inspections.
Old Dec 5, 2011 | 11:02 AM
tdrendel's Avatar
Default my 83 245 dl chugged to a stop yesterday
driving down the raod yestrday and my 83 245 started chugging then died completly. since my gas gauge doesnt work i tried gas first with no luck i unplugged the MAF and plugged back in and it ran fine does this mean the sensor is bad or do i have another problem???
Old Dec 5, 2011 | 12:53 PM
tdrendel's Avatar
Default 83 b23f running like hell!! i need help!! Q's
my 245 is running like hell!! very rough idle wont stay running for more than a couple seconds there doesnt seem to be any vacum leaks so im geussing its a sensor i unplugged the MAF and plugged back in and it ran fine for an hour or so then it died again any suggestions?????
Old Dec 6, 2011 | 06:20 AM
act1292's Avatar
Since you mention that your gas gauge doesn't work, I would check out your fuel system and make sure it is all working properly. You have two fuel pumps - one pre-pump in the gas tank and one underneath the car just forward of the left rear wheel. Many times with age and rust, the wiring going to the in-tank pump/fuel guage sender breaks and you lose your in-tank pump as well as your gas guage.
Use the steps found here to check out the fuel system:
In the Tank - 240 Volvo Tank Pump and Sender
If your fuel system checks out, the next place I would check is the hall sensor in the distributer. I'm not familiar with your vintage of cars but do a search here and you should find other threads about how to diagnose a faulty hall sensor.
Good luck.
Old Dec 6, 2011 | 03:34 PM
tdrendel's Avatar
the fuel pumps seem to be fairly new the undercar looks brand new and based on the silicone on the in tank pumps cover id say that one was probably done too
Old Dec 6, 2011 | 07:07 PM
lev's Avatar
lev
I think you have a good case for a bad MAF sensor. They will do exactly that, off/on, intermittently acting up, driving one crazy--they do go bad, a LOT!
Old Dec 7, 2011 | 10:24 AM
tdrendel's Avatar
i got it started by unplugging the maf does that mean its bad????
Old Apr 25, 2017 | 01:33 AM
Anthony1000's Avatar
I'm here trying to guess what a MAF sensor is, please educate. Thanks
Old Apr 25, 2017 | 01:56 AM
dytha99's Avatar
MAF sensor = Mass Air Flow sensor
aka
AMM sensor = Air Mass Meter sensor
located after the air filter in the big hose the runs to the throttle body.
Old Apr 25, 2017 | 01:43 PM
anthony1000, your 1980 is probably KE-Jet aka CIS-E, and won't have a MAF/AMM at all. the MAF/AMM is used with LH electronic injection.
tdrendel
Apr 11, 2012 06:32 PM
tdrendel
Feb 25, 2012 09:31 AM
tdrendel
Dec 11, 2011 08:46 PM
tdrendel
Nov 27, 2011 04:44 PM
wishpony
Jan 11, 2009 07:18 PM
