leaking intake manifold
Old Apr 15, 2005 | 07:08 PM
wavewright's Avatar
Default leaking intake manifold
i did the hose to the ear thing to check for leaks and found something around the #4 manifold. as long as there arent any hidden lines around there it think its a bad intake manifold gasket. the only thing i saw was a hose going from the block through the fire wall ( i assume this is for the heater). would this also explain the gas smell? is this the reason for my idle surge when engine is cold? boy i hope this is the cure to my puzzle.
Old Apr 15, 2005 | 07:10 PM
Default RE: leaking intake manifold
Most likely the manifold gasket.And yes you will smell gas from it the computer is making the car run rich.
That would also cause a little idle surge.
If you are going to replace the gasket clean the throttle body and idle motor at the same time.
Old Mar 22, 2020 | 12:37 PM
kellerwaldron's Avatar
What is the hose to ear thing? i have a intake leak that i cannot track down.
Old Mar 22, 2020 | 02:10 PM
its a poor man's stethescope :-) For intake leaks you can start by spraying some carb cleaner around the air intake tubing, where the manifold meets the head and around the injectors - if some gets sucked in, it will bump up the idle. More likely you have a vaccuum line issue and if your first visual inspect doesn't find anything (particularly for hoses buried under something like a manifold or the intake air box), you may need to have a smoke test done. Check Youtube for some vids on making your own smoker or have a shop with equipment do the test.
960 rookie
Sep 25, 2011 08:52 PM
plinehan1
Feb 22, 2011 09:30 PM
Johnboy
Sep 11, 2008 06:02 AM
y2kvfr
Sep 26, 2007 10:11 AM
wavewright
Apr 12, 2005 09:16 PM
