Leaking Oil: Cranks Seal
Old Nov 24, 2017 | 05:25 PM
tbuchan's Avatar
Default Leaking Oil: Cranks Seal
Hello, I have my old 1993 240 Wagon and it started leaking oil.
They diagnosed it to be the crank seal leaking.
Is this the same as the crankshaft seal?
Any information would be great.
Thanks
Old Nov 24, 2017 | 11:03 PM
lev's Avatar
lev
yes, or rear main seal. have to take out the tranny to change it. you may want to make sure the crankcase ventilation is not plugged up creating pressure that blew the seal.
Old Nov 26, 2017 | 09:21 PM
there's a crank shaft seal on both ends of the motor, the front one is behind the crank pulleys, while the rear one is between the engine and transmission.
Old Nov 27, 2017 | 12:47 PM
fsh2's Avatar
Yes, my front crank seal leak was caused mainly by increased crankcase pressure resulting from PCV system malfunction, not a bad seal. In that situation, you can replace the seal and the leak will continue.
nightmarevolvo
Feb 4, 2023 06:20 PM
Luvmateo
Nov 30, 2014 08:22 PM
rainman14624
Sep 20, 2010 09:22 PM
ebrobb
Feb 15, 2007 02:52 PM
Clueless Scott
Jul 1, 2006 10:39 AM
