MAF questions, on 1983 242 b23f
Old Nov 30, 2025 | 06:43 PM
dougburgy's Avatar
Default MAF questions, on 1983 242 b23f
Hello!
If my MAF is plugged in, car starts fine as normal, but will want to die if I don't work the gas pedal. Probably after around 10 seconds. It will start fine again, but then same stall issue. IF I unplug the MAF it will start and continue to run without dying, however it kind of surges, runs rough, and smells rich. I removed maf and cleaned with mag sensor cleaner and plugs. I let dry and put back together, but no change. Kind of guessing it's bad maf but haven't done multimeter testing at plug, or searched for vac leaks yet. Which I plan to do soon. Thoughts??
Old Dec 1, 2025 | 01:21 PM
Golden redblock's Avatar
Default Maf
L&D Volvo Redblock parts
Atlanta Craigslist
Shipping Nationwide!!!!
Old Dec 1, 2025 | 02:06 PM
dougburgy's Avatar
Default ??
Hi Golden,
sorry, didn't completely get the meaning of your reply. Are you saying you believe from explanation of symptoms that you think my maf is shot, that I need a new one, and that a craigslister in GA can supply one? Thanks! Doug
Old Feb 17, 2026 | 12:06 PM
renardanderson2's Avatar
dajson
May 29, 2013 07:15 AM
slimflex2
Aug 15, 2012 11:59 PM
cheesenacho
Apr 24, 2012 06:10 PM
Psaboic
Nov 23, 2009 10:28 PM
BlazeS70
Sep 1, 2009 09:47 PM
