Main Pulley
Old Mar 7, 2006 | 03:19 PM
rotarykid7's Avatar
Default Main Pulley
hey guys, i have two questions about the main engine pulley on my 93 940 8v
does the main pulley need a puller to take off?
and does anyone know off hand what the socket size is?
thanks
Old Mar 7, 2006 | 09:00 PM
Default RE: Main Pulley
It is a 24mm socket and no puller needed to get it off.
You can use 2 prybars and carefully pry between the pulley and the timing cover on each side. It will walk off doing it that way.
Old Mar 8, 2006 | 09:55 PM
rotarykid7's Avatar
thanks
when putting the crank pulley back on how do you tighten the bolt if you don't have the Volvo tool?
also separate question but does the 93 940 have a drain plug for the cooling system or do you just drain it from the radiator hose, and where is the drain?
Old Mar 8, 2006 | 10:11 PM
I have a pair of Chain Vise grips that I use.
For the Drain there is one in the Block. It is next to the Downpipe for the Exhaust.
If it is Turbo then it might be in the oil cooler lines.
Old Mar 8, 2006 | 10:16 PM
rotarykid7's Avatar
thanks, i probably would have spent half a day trying to find that.
i have a nice set of strap wrenches see how they work, or i'll get a vise grip like that
what size chain is yours?
Old Mar 8, 2006 | 10:36 PM
Im not sure I just walked on the tool truck and pointed I want those!! LOL
Old Mar 8, 2006 | 10:56 PM
rotarykid7's Avatar
oh man i wish we had tool trucks around here
thanks for the help
flyboy
Aug 30, 2016 12:43 AM
guest01
Nov 5, 2011 10:11 PM
jcmartin
Sep 20, 2008 09:19 PM
white out
Oct 10, 2007 10:15 AM
anubyss
Nov 2, 2005 11:47 AM
