Manual Shifter drops in an 89 240 DL
Old Aug 12, 2013 | 02:32 PM
MartinJon's Avatar
Default Manual Shifter drops in an 89 240 DL
Hey all so I know that the shifter is seated in a ring and that ring, which may be plastic must have just worn thin or something but I have no idea what the name of that would be. so I am having trouble finding the part number. The shifter still holds a bit but it drops every couple miles due to vibration or bumps in the road. Any help in finding the part or an exploded view of the shifter assembly would be a huge help.
thanks
MartinJon
Old Aug 12, 2013 | 05:05 PM
I'll look it up when I get home. probably can find you a parts diagram too.
do you have the M46 4 speed with electric overdrive (switch on top of the shift ****), or the M47 5 speed transmission ?
Old Aug 12, 2013 | 09:01 PM
looks like the M47 5-speed is the only stickshift on an 89, so...
missing PN's...
42 - ball socket lower - 1232173 - 4drs chassis -436871, 5drs chassis -890394
- ball socket lower - 3520209 - 4drs 436872-, 5drs 890395-
43 - rubber damper lower - 1232605 - 4drs chassis -436871, 5drs chassis -890394
- rubber damper lower - 3520197 - 4drs 436872-, 5drs 890395-
44 - locking plate - 1209802
45 - 2 each flange screw - 948663
46 - plug - 1340499
Old Aug 13, 2013 | 07:47 AM
MartinJon's Avatar
This is awesome thanks - so helpful
jmarble
Sep 2, 2022 05:28 PM
xDread92x
Jul 21, 2019 04:18 PM
jasond011
Sep 13, 2010 04:02 PM
sandraqu
Dec 24, 2009 02:36 PM
zysoclaplem
Jul 22, 2005 07:58 PM
