Motor Mount Renewal Quick Questions
Old Feb 15, 2020 | 03:51 PM
mschultz373's Avatar
Default Motor Mount Renewal Quick Questions
I I am replacing both motor mounts on my '85 240 DL tomorrow and have two qucik questions.
1: A tips guide on Swedish Bricks recommends unbolting the motor mounts from the front axle, then jacking up the vehicle, then jacking up the engine and proceeding to remove the mounting brackets and replace the mounts. Is this the correct procedure? It seems to me that jacking up the vehicle first - then unbolting the mounts from the front axle, then lifting the engine would be the right procedure.
2: The same tips guide says not to lift the engine using the oil pan. But Haynes says to lift the engine under the sump pan? But I have also read that the engine can be supported with the transmission? Where is the best place to put the jack to lift the engine?
3: is it necessary to remove the top mounting bracket to replace the mounts? It appears to me that the mounts could be fitted into the top brackets without removing them. But perhaps I will run into that as I do the job....
Thanks for the advice and help.
Old Feb 15, 2020 | 03:59 PM
I'd use an engine hoist from above rather than trying to lift it from below.
btw, the Haynes books aren't worth the paper they are printed on.
Old Feb 15, 2020 | 04:01 PM
Luckily I picked mine up at a thrift shop for $2....
The Bentley has no info on the motor mounts that I have found.
Dagaan
West
Feb 14, 2017 10:00 AM
Dagaan
Oct 23, 2016 08:13 AM
JasnAl
Aug 10, 2013 06:17 PM
Sofar.
Jun 11, 2009 11:24 AM
adam
Jan 22, 2006 02:04 AM
