My $200 1986 Volvo 245DL
Old Jul 22, 2016 | 07:35 PM
  #81
jands's Avatar
you in New england?
Old Jul 23, 2016 | 06:12 PM
  #82
Cwazywazy's Avatar
Originally Posted by jands
you in New england?
Yup, CT. The only junkyard 240 I've found is a '92 at Sams u pull it in MA.
Old Jul 24, 2016 | 12:28 PM
  #83
jands's Avatar
There are a few over by bridge water state in a large junk yard. It's where I been pulling for my 960
Old Jul 24, 2016 | 02:07 PM
  #84
Cwazywazy's Avatar
Could you get me a link to the junkyard site?
Also my AC seems to have leaked out while I was away. Wouldn't turn on and when I hooked up my manifold the low side was at 10psi with the AC off. Couldn't find the leak with a black light so I just threw in a can of R134 that I still had and it's at least enough to keep me from getting sweaty.
I'm spending a lot on refrigerant alone. Worth it to stay cool though.
Old Jul 24, 2016 | 05:34 PM
  #85
Cwazywazy's Avatar
Talking to a guy on Craigslist about buying a set of corona wheels (The vaney ones) complete with caps for $50. If I can get those, I think they'd look pretty good.Anyway, it's time for tonight's new problems:
The AC won't cycle on/off. If the **** is anywhere but off, the AC compressor stays on. Also the blower doesn't shut off even with the AC off. I always have it on, but still. Then the coolant leak which I made a separate thread about. And there's a minor leak at one of the valve cover bolts where the spark wire separator is attached. Wasn't loose at all, but I still tightened it a bit. Still sounds like it's falling apart when I go fast from a stop, but that's normal.
Old Jul 25, 2016 | 03:07 PM
  #86
silvermine's Avatar
i can appreciate what you are doing with this beast but there are 240's out there in the 1800-2500 range that appear (at least from craigslist ads...) to be in very good shape...
just sayin..
Old Jul 25, 2016 | 08:31 PM
  #87
Cwazywazy's Avatar
just sayin..
I know, I know. The floorpan is pretty damn rusty. But still, the engine has plenty of life left in it so I might as well drive it until I fall out through the bottom. Also it's my first car, so I'm learning a lot.
Did some dirt donuts earlier. It's fun.
Old Jul 26, 2016 | 10:25 AM
  #88
jands's Avatar
Originally Posted by Cwazywazy
Could you get me a link to the junkyard site?.
Here is the fb page
https://m.facebook.com/Middleboro-Auto-Salvage-158827150814256/
Old Jul 26, 2016 | 01:22 PM
  #89
Cwazywazy's Avatar
Decided to take off the rear muffler just to see how it sounds. Used the exhaust clamp to finally clamp the cat onto the resonator as it was just sitting in there.
It's not bad, but I probably still won't keep it this way.
Old Jul 27, 2016 | 01:57 PM
  #90
Cwazywazy's Avatar
Rev limiter around the 2:50 mark.
Old Jul 30, 2016 | 03:44 PM
  #91
Cwazywazy's Avatar
Popped my muffler back in with a new clamp, topped off my AC until it stopped bubbling in the sight glass (Much colder now), and spent about 5 minutes with a rag and some acetone to make my trim and mirrors to look like new again. It wasn't terrible before, but I got wax on the black stuff under the windows which made it look pretty bad. Then I washed it.
Old Jul 31, 2016 | 04:14 PM
  #92
Cwazywazy's Avatar
My car is making new sounds. There's the weird knocking thing that happens when the clutch is slipping in first, but now it makes this weird rapid clicky/knocky sound. It happens in all gears but it's the worst in second. No idea what it is. Only happens when I get on the gas, like past halfway.
Old Jul 31, 2016 | 04:23 PM
  #93
Cwazywazy's Avatar
I think the gear stick shifted a bit.. (No, but really.)
Before I got the car, in first gear:
Now, in first gear:
Neutral:
Can't see anything wrong with the engine mounts.
Old Jul 31, 2016 | 04:56 PM
  #94
Cwazywazy's Avatar
Old Aug 3, 2016 | 08:25 PM
  #95
Cwazywazy's Avatar
Okay, so I managed to replace the trans mount all on my own. It was a bitch of a job, but I did it. Only one rounded off bolt too!
The knocking in first when slipping the clutch is finally gone, but the new noise and the shifter being moved over still persist. Except now the noise is around low-half throttle, high throttle doesn't really make it. And I can make the noise just by revving the engine.
Also after work I pushed the gas down and the car fell flat on its face. And it idled kinda rough, so I pulled over and wiggled all the plug boots. It persisted, so I stopped to try and record the issue, then it magically went away. I've had this before too, it's weird.
Old Aug 4, 2016 | 11:53 AM
  #96
Cwazywazy's Avatar
Old Aug 5, 2016 | 06:58 PM
  #97
Cwazywazy's Avatar
For some reason now the engine runs like crap until it's fully warmed up. Like, bad idle and it'll fall on its face past 1/4-1/2 throttle. A steady 30MPH with your foot on the floor isn't fun. A shop is gonna take a look underneath it for me on Monday, see what's up with the trans.
Old Aug 7, 2016 | 10:39 AM
  #98
Cwazywazy's Avatar
Any ideas with the bad running when cold?
Old Aug 9, 2016 | 02:05 PM
  #99
Cwazywazy's Avatar
According to my mechanic I toasted the engine mounts. Which I thought were fine since the engine doesn't move very much at all when I push and pull on it and they looked okayish.
He did use the word "shot" a worrying amount of times on the phone though.. I thought my frame was mostly solid, but turns out above where the trans crossmember bolts in the frame is just rotten. Oh well. My plan is to keep it running good, get that B230FT+ from the 780 Bertone, then in the future when the cancer is too bad I'll get something with a good body/frame to swap the engine and bits over.
Old Aug 9, 2016 | 09:49 PM
  #100
jands's Avatar
i know when my 960 ran like crap when cold it turned out to be the MAF sensor......idk if urs has one in 1986??? first thing i would look into
