need help identifying sensor '83 240
Old Jul 24, 2012 | 08:23 PM
fochs's Avatar
Default need help identifying sensor '83 240
I done broke this! what did I break? It goes in the hole to the bottom right of the sensor with the yellow wire. It is connected to a brown wire.
Attached Thumbnails need help identifying sensor '83 240-wp_000005.jpg   need help identifying sensor '83 240-wp_000007.jpg   need help identifying sensor '83 240-wp_000009.jpg
Old Jul 25, 2012 | 01:39 AM
lev's Avatar
lev
Gauge temperature sensor.
Old Jul 26, 2012 | 09:17 AM
swiftjustice44's Avatar
Sure looks like an oil pressure sender to me...but it belongs on the other side of the motor...
Old Jul 26, 2012 | 12:58 PM
95doyle's Avatar
I'm pretty sure that's a temp gauge sender. I broke it also on my 1993 240 and had to replace it. You should be able to pick one up at your local parts store pretty cheaply.
Old Jul 26, 2012 | 01:27 PM
Here's pictures of replacement senders for an 83 240 w/ LH2.0 FI.
The oil sender...
The sender for the temp gauge...
The weird thing is the op sender mounts on the other side by the oil filter and alternator. The gauge sender is, I believe, the yellow wired sender by cylinder 2 while the temp sensor for LH is located by cylinder 3. I don't know what would be mounted lower and to the right...
Old Jul 26, 2012 | 05:03 PM
bitter356's Avatar
Question Switch?
It might sound a little careless but, single pole switch that is grounded to close. How about grounding the wire and then ignition on and look at your instruments..... Of course disable ignition and fuel pump.
Old Jul 28, 2012 | 02:26 AM
Titan Joe's Avatar
Might be this: Volvo Knock Sensor (240 244 242 245) Genuine Volvo 1317296 | FCP Euro
Old Jul 28, 2012 | 10:39 AM
fochs's Avatar
Originally Posted by Titan Joe
Looks to be this part, thanks! wow that is an expensive (screw)!
Old Jul 28, 2012 | 04:12 PM
scrounge one off another LH 2.0/2.2 car LH2.4 uses a different one.
I did think the yellow wire was for the dashboard temperature gauge sensor, which is separate from the ECT engine temp sensor used by the ICU and ECU. all three of those (knock, dash temp, and ECT) are under the intake manifold, while the oil pressure sensor is near the oil filter on the other side. (digs up his 240 greenbooks...)
oof. no 83 on this disk, just <= 1980 and >= 1984... ok, i'll look at the 84 book....
hmm, I don't see a knock sensor at all on the 84 diagrams? the temp sensor on the block has a blue and black (ground) wire.
the yellow wire on an 84 is definitely the dashboard engine temperature gauge sensor which is shown as having the long thin end, like the above pictures suggest.
I guess its possible someone put the wrong sensor in previously... or plugged the wrong wire into the wrong place.
rjb44
Feb 6, 2011 07:48 AM
andrei3333
Dec 26, 2010 10:22 AM
ZackieDarko
Feb 1, 2007 08:36 PM
jcmartin
Aug 12, 2005 11:20 PM
