Need help with timing tension
Old Feb 3, 2019 | 04:53 PM
new2Volvos's Avatar
Default Need help with timing tension
Hey guys i'm new here. I'm new to volvos but nor working on cars. My wife inherited a 93 240 wagon from her dad and wants to get i back on he road. The front crank seal was leaking horribly. I replaced all 3 while I was there. he issue I have is:
New timing belt and tensioner...I cannot for the life of me get the tension tight on the right side(cam to intermediate gear) there is substantial belt play. The new tensioner sits flush to the block and everything is lined up as marked before disassembly.
ANY AND ALL HELP IS GREALY APPRECIATED!
Old Feb 3, 2019 | 05:00 PM
lev's Avatar
lev
Something must be off wth the parts you are using. How much a play is there? Is the belt may be too long? Is the tensioner taking up the slack? I can't think of anything else...
Old Feb 3, 2019 | 05:09 PM
new2Volvos's Avatar
The tensioner is taking up slack and there's about 1/8 inch play maybe a touch more. I forgot to mention I also put the old belt on and ran into the same issue
Old Feb 3, 2019 | 06:25 PM
jagtoes's Avatar
Compare the new tension-er assembly with the old one. What's the difference.
Old Feb 3, 2019 | 09:34 PM
lev's Avatar
lev
So, with the old belt and tensioner you had 1/8 inch play as well? The tensioner should take up the slack when extended. It must be something simple we are overlooking--not too many elements here, belt, tensioner, 3 pulleys...
Old Feb 4, 2019 | 06:30 PM
is either the camshaft or intermediate shaft not turning freely ?
Old Feb 4, 2019 | 06:31 PM
there's two different timing belts and pulley sets depending on the age.... some have round teeth, some have flat square teeth, you have to use the belt that matches your pulleys. I *think* the round ones were later, but I could be wrong.
Old Feb 5, 2019 | 02:59 PM
new2Volvos's Avatar
Both pulleys turn freely and the belt is round tooth. Also, both tensioners are identical. I will try to load a picture later.
Old Feb 6, 2019 | 09:02 PM
new2Volvos's Avatar
Figured it out, when the new tensioner was on it sat flush until putting the belt back. There was a slight angle issue. All is well now. Thanks for he feed back!
oragex
Feb 8, 2014 12:17 PM
nuclearseal
Apr 17, 2013 08:34 PM
kc2mrg
Apr 30, 2012 09:38 PM
holobox
Oct 17, 2009 08:23 PM
melkavitch
Sep 3, 2009 05:01 PM
