240 timing belt "jumps"
Old Sep 3, 2009 | 04:05 PM
melkavitch's Avatar
Default 240 timing belt "jumps"
Hi,
I'm thinking about getting an '87 240 wagon that has a problem. The owner says the timing belt "jumps" in cold weather and the car stalls. Is there a way to fix this? I don't mind putting some time/money into this, as my '96 Explorer has been diagnosed with terminal rustitis. Any thoughts - the tensioner beign bad perhaps?
Thanks,
Mike
Old Sep 3, 2009 | 04:58 PM
fredbyte's Avatar
The tensioner could be bad, but the alignment among the pulleys could also be off. The easiest way to tell is to take the upper timng belt cover off and rotate the crankshaft pulley by hand a few times to see if the timing belt starts to slip off the overhead cam pulley.
Old Sep 3, 2009 | 05:01 PM
TURBO 245's Avatar
I would say the tensioner is bad,replace the belt and tensioner and you should be good to go.Also I would check the cam,intermediate shaft, and crank seal for seepage.
Dan
oracleminded
Sep 17, 2012 07:50 PM
Calyptra
Nov 3, 2009 12:37 PM
cbrack
Sep 12, 2008 07:39 PM
DJboozeAlot
Nov 27, 2006 08:54 PM
joelovescarmen
Aug 23, 2005 01:35 AM
