Timing belt tensioner spring
Old Apr 17, 2013 | 07:33 PM
nuclearseal's Avatar
Default Timing belt tensioner spring
Alright, I'm racking my brain on this and it shouldn't be that hard.
The timing belt tensioner, is it possible that the spring itself needs replacing and if so where to get one.
I compressed it and put a drill bit in to hold it to get the timing belt on, but when I go to put the timing belt on it won't compress anymore and I can't slide the timing belt on the last little bit.
I have tried pulling the tensioner to the left to relieve more pressure but it won't budge. It looks like it could move a little more but it won't budge. I know I'm not as strong as I once was but yikes!!!
Any tricks on this one? I've searched everywhere and it just says to pull it to the left and slide the belt over. Not working on this one.
Old Apr 17, 2013 | 07:54 PM
Are the belt's teeth seated in all the drive pulleys?
normally, you replace that tensioner when you replace the timing belt, as cheap insurance.
Old Apr 17, 2013 | 07:58 PM
Yes I have a new tensioner that came with the kit from FCP, but it doesn't have the actual spring or the bolt that it goes over, they are reused.
All the teeth line up, I can get all three marks perfect but then I just can't get the belt over the tensioner and it won't budge. Was thinking the actual spring itself needs replacing, I was looking and couldn't find exact specs but I think it's 2 3/4 x 5/8, mine is 5/8 but the length is stretched out to 2 14/16
Old Apr 17, 2013 | 08:34 PM
just saw your other post about the wrong toothed camshaft pulley.
girlie
Dec 26, 2007 09:52 PM
ramp
Nov 26, 2007 08:16 PM
FBookhoo
Oct 25, 2007 04:41 PM
MikeySq
Oct 18, 2006 10:01 AM
Moparman
Oct 17, 2005 08:33 AM
