Need help trying to figure out how to remove a trunk lock on a 940 gl turbo
Old Aug 24, 2010 | 02:13 PM
940glowner's Avatar
Post Need help trying to figure out how to remove a trunk lock on a 940 gl turbo
I have been on the hunt for a new trunk lock for my 1992 940gl, and long behold i have located one. But the lock is located at pull apart and is still attached to the trunk of a 940 gl turbo i am not sure what year it is. Does anyone know how to remove the lock from the inside of the trunk. I need to know as soon as possible because i am now sure that the lock is still on the trunk at pull apart.
any help would be great as soon as possible......................
Thanks again in advanced for any help i may receive..........
Old Aug 25, 2010 | 11:22 PM
940glowner's Avatar
i finally got the lock off the trunk
Old Aug 26, 2010 | 11:55 AM
anotherskait@yahoo.com's Avatar
How'd you do it?
Old Aug 28, 2010 | 12:04 PM
940glowner's Avatar
there is a clip that is attached to the trunk. If you look at your trunk lock on the outside of the trunk. look inside the trunk hood and you should see a clip that the trunk lock is attached to you, have to find where the lock is either glued there or something, of that nature. I will post a more detailed description later, my friend told me how to do it so i will ask him, and post how to remove it.
Old Jan 31, 2021 | 11:34 AM
Zdoobs's Avatar
Default Trunk latch removal? How'd you do it?
I've got a 740 and need to replace the latch, before I do, I have to pull one from the junk yard but don't see how to remove the gold plate on the inside holding it in place. How'd you do it?
Old Jan 31, 2021 | 11:45 AM
lev's Avatar
lev
There a U clip that holds the trunk lock in place Just use a chisel or screwdriver to slide the clip off to free the lock.
Are you talking about the trunk lock or door?
mrenglish78
Nov 2, 2017 10:34 AM
gabyman97596
Jun 22, 2010 02:41 PM
stevied
Jul 2, 2007 03:08 PM
likesspace
Jun 23, 2007 01:40 PM
luckytweaker
Aug 30, 2006 08:59 PM
