1992 240 Rearview Mirror Replacement
Old Jan 26, 2021 | 06:30 PM
RustNeverSleeps's Avatar
Default 1992 240 Rearview Mirror Replacement
Hi ...
Any tips on removing the outer housing in the ceiling to replace the rearview mirror. It has to be removed so the two bolts can be exposed. I have read that there are two plastic tabs and they can easily break it not careful.
Appreciated.
Old Jan 26, 2021 | 07:06 PM
Originally Posted by RustNeverSleeps
Hi ...
The mirror is designed to break away if hit by maybe a human head - just grab and pull - it will come off! And yes on the sedans (i think) the square plastic cover has tabs that will break because they are xxx years old dried out plastic.
Old Jan 26, 2021 | 08:56 PM
Yes, the cover is what I am worried about. Once I get the cover off, it should be easy. Just didn't know if others have had luck getting the cover off w/o breaking the tabs.
Old Jan 27, 2021 | 03:36 AM
when the mirror is unsnapped, its cover stays on it.
Old Jan 27, 2021 | 08:20 AM
lev's Avatar
lev
You can carefully pry off one end of the cover to unsnap it, it all depends how brittle it is after all the years in the sun.
Old Jan 31, 2021 | 04:49 PM
Replaced today with a used OEM part. Unfortunately, the plastic cover was brittle and broke. Other than that, easy job. Oh well, not the end of the world ... better than a stick up newer style mirror.
Dee
Nov 14, 2023 12:15 AM
fjp
Dec 4, 2021 07:16 PM
ckuttner
Feb 4, 2020 10:33 PM
Andy Watkins
Mar 25, 2015 07:01 PM
Nivekrg
Aug 27, 2009 08:59 PM
