Trunk Lid Won't Close
Old Jul 30, 2011 | 06:09 PM
mrenglish78's Avatar
Default Trunk Lid Won't Close
Have a 2009 S40. The trunk lid will not close. If it is a fuse problem, don't know what fuse to replace. Need help. Thanks!!!
Old Aug 22, 2011 | 12:39 PM
Counselor828's Avatar
Can u give us some more info? Is the problem that the trunk lid (deck) will not fit into the lower part of the trunk frame (body work problem)? Is the problem that u can close the trunk but it will not latch (mechanical problem)? Is the problem that the trunk will latch but later become unlatched (not locked in place, maybe electrical problem)? Is the problem that the deck cannot belowered into positon and is stuck in the upright position (problem with trunk strut)? Add some facts for us, and then we can try and focus on the cause of your trunk problem.
Old Nov 28, 2012 | 12:08 PM
rkroninger's Avatar
Default same issue
I'm having the issue with the mechanical problem you are talking about. i can close the trunk but it won't stay latched. I tried locking the trunk with the key and it doesn't lock. Do you think it might be the actuator gone bad?
Old Feb 25, 2015 | 03:47 PM
DeanY's Avatar
Default S 40 trunk lock not latching
My 05 S40 had a broken piece in the lock and would sometimes open the lock and sometimes not. I ordered a new replacement lock and installed it. It worked once and now will not latch. I can try to physically push the latch closed and it will not hold closed. It is as if the emergency handle has been pulled and stayed pulled but this is not the case. I took the lock back off and still will not latch closed. Is there something electrically that I am missing? We think the car was broken into when in new York city a couple of weeks ago and have had problems with the trunk lock since. It was very cold and thought the lock might have broken from the bitter cold. any help would be appreciated. Do I need to reset the alarm system? The lid open warning light came on and stayed on even when the lock was locked and working.
Old Feb 28, 2015 | 04:06 PM
DeanY's Avatar
Default Found open wiring in harness
Checked the wiring harness on the S40 trunk taking it completely out and ringing out each wire. Found the black wire from the connector inside the top of the trunk lid to the lock connector not showing continuity. Thus a broken wire. Will replace the harness. Could have patched in another but thought I would put in new instead. Not real easy to get the connector loose in the trunk. Hope this solves all problems.
Old Mar 2, 2015 | 08:23 AM
mf70's Avatar
Thanks for the update. It helps all of us.
Old Mar 4, 2015 | 01:42 PM
DeanY's Avatar
Replaced the Trunk wire harness and all is fixed! Yea! It only took about 10 minutes to replace the harness. Harness comes with all the tie wraps and holders in place. Hardest part was taking out the existing wire holders with out a tool to do so. Hope this string helps others with the problem of the trunk lock not locking and the lid open dash warning light staying on.
Old Nov 2, 2017 | 10:34 AM
CS2011's Avatar
Thanks to this thread I was able to find the same problem. I also used a multimeter set to beep when a circuit is complete and tried all the pins and only 1 coming from inside the trunk (6 pins) to the latch mechanism inside the trunk lid (4 pins) wasn't connected. To double check that this was the issue I ran an external wire and sure enough the lid worked fine. Going to replace the harness using the Volvo part number 30724788. https://parts.volvocarsannapolis.com/p/Volvo__/Wiring-harness/42873333/30724788.html?partner=googlebase_adwords&kwd=&orig in=pla
This was on a 2011 S40
Last edited by CS2011; Nov 2, 2017 at 10:35 AM. Reason: Forgot to include car type
timtatum
Jan 8, 2025 09:44 AM
AzNick
Dec 15, 2010 10:25 AM
andreop
Nov 7, 2008 09:50 PM
andreop
Nov 7, 2008 07:23 AM
nedflack
Dec 16, 2004 03:09 PM
