Newbie: '88 240GL in Australia - questions
Old Dec 18, 2013 | 04:45 PM
thomegwaan's Avatar
Default Newbie: '88 240GL in Australia - questions
Hi all,
New here, and new to Ovlovs (although my grandfather always drove 240s, so perhaps not . Recently bought an '88 240GL with M47 5 Speed manual and very happy with her. The B230F motor is running great since I replaced the dizzy cap and rotor, and fitted a K&N air filter.
I was just starting to get excited about the idea of turbocharging her but then I saw this thread: https://volvoforums.com/forum/nitrou...-b230ft-25272/
Can anyone suggest any cheaper/easier performance mods for this motor?
Also, she has one issue, being very hard to select reverse - I suspect some sort of clutch issue but would be interested to hear if anyone knows of a common fault with this setup. I can soldier on with it indefinitely - it is just necessary to switch the motor off to engage reverse!
Cheers!
Old Dec 19, 2013 | 09:02 AM
lev's Avatar
lev
well... anything is possible. go to turbobricks for more on turboing.
your tranny? hard to say without seeing it. a shop will tell you if it is clutch or the tranny itself. don't want to guess.
Old Dec 19, 2013 | 12:49 PM
there are no cheap/easy performance mods. a turbo car has a higher volume fuel pump, different heads (sodium filled valves), different pistons (to lower the compression ration to prevent predetonation), bigger radiator, squeeze the intercooler into there... the best way to do it is to find a b230ft powered 740/760 and transplant nearly everything under the hood.
Volvo never used the M47 with a turbo as its not strong enough, the turbo manuals used the M46 4-speed plus overdrive.
boko
Dec 17, 2023 12:08 PM
ctmca9
Feb 12, 2014 09:38 PM
singledad
Apr 16, 2013 08:24 PM
denno
Oct 11, 2012 11:52 PM
Nick I
Dec 12, 2005 02:09 AM
