Newbie to Volvos, need help w/brakes
Old Jun 23, 2005 | 06:48 PM
Kilika's Avatar
Default Newbie to Volvos, need help w/brakes
Hey guys, I'm new to Volvos. I own a 92 Toyota MR2 which is a totally different animal. Anyways, I'm doing a brake job for my grandpa's '88 240 since he always sees me working on the MR2. It is getting new rotors and pads. I hit a problem regarding the pistons, I need to push them back to fit the newer, thicker pads in. I've done a brake job before so I'm kinda going through this without any references so far and pretty much learning as I go. Here are some pics of what I've done so far. Please let me know if I'm doing anything wrong.
Old Jun 23, 2005 | 10:17 PM
Default RE: Newbie to Volvos, need help w/brakes
You need to push one side at a time back.I usually install the pads first before installing the new disk.
Old Jun 24, 2005 | 10:17 AM
Ignavus's Avatar
One way to get the pistons back into their bores is to install the calipers, temporarily re-install the old pads (without the shims or anti-rattle springs), put appropriate lengths of tubing over all three bleed nipples and place the ends in a bottle, open the bleeders and squeeze the pads back with a large set of channel locks or any thing else that you have that will reach from the pad lip to the back of the caliper. That way all of the old contaminated brake fluid that dead ends in the piston bores does not get pushed back upstream. Some really picky folks will even clamp the flex lines with a brake line clamp tool ( you have to do it on an ABS car) , but I think most of the 240's are getting too old for that unless the flex lines have been replaced.
When you are done, you can go ahead and bleed the lines just to make sure there is no trapped air, do the top bleeder first then the two side bleeders.
Old Jun 24, 2005 | 11:30 PM
reg's Avatar
reg
I simply use an old pad up against the pistons and use a c-clamp and compress the pistons. Make sure that you have sufficient room im the master cylinder resovoir to accept the added brake fluid.
Old Sep 18, 2021 | 11:38 AM
cove6haru's Avatar
please? what happens if you don't open the reservoir cap or bleed screws when you push the piston in on an abs v70? not clamped either
Old Sep 18, 2021 | 11:48 AM
lev's Avatar
lev
Usually nothing, just the fluid backs up in the reservoir; hopefully won't overflow as brake fluid strips the paint. I never open the bleed screws when depressing the pistons, I just keep an eye on the level of the fluid in the reservoir. I've never done a V70 just older 740/940/240 with ABS and without.
Old Sep 18, 2021 | 12:01 PM
cove6haru's Avatar
okay thank you, I replace the pads and rotors and now they're not bleeding and I'm kind of at a loss
Old Sep 18, 2021 | 01:20 PM
lev's Avatar
lev
You don't need to bleed them if you didn't open the system, or you feel they need it for some other reason. How is the pedal pressure?
Old Sep 18, 2021 | 03:16 PM
nibroc's Avatar
it's best to change the fluid also
bigarms23
Apr 21, 2015 07:17 AM
ryanturbos40
Nov 24, 2014 06:28 PM
red_t5
Mar 31, 2009 08:12 PM
Branan
Dec 8, 2005 09:15 PM
Beau850
Jun 5, 2005 01:05 AM
