no brake pressure
Old May 18, 2005 | 10:52 AM
drfrankenstein's Avatar
Default no brake pressure
i have been having some serious braking issues with my new 79 244dl.. i bought it being told the brakes needed to be bled, well that was 2 months ago and every week they have to get rebled, they wont hold pressure after driving the car for a couple days. i am asuming maybe a bad caliper piston boot, but it could be something else... any opinions... btw i am not leaking or loosing break fluid at all and i installed a new master cylinder thinking that might have been the problem and it wasnt, so i replaced the elbow that the brake booster vacuum line connects to at the brake booster, and that didnt help.. any suggestions would be nice
Old May 18, 2005 | 11:47 AM
Default RE: no brake pressure
Something sounds fishy.It shouldn't loose pressure like that unless it is leaking fluid.
The only other thing I could think for you to look at would be the Branch valve or some know it as the failure valve.It is located on the left side of the car on the frame.It has a wire going to it.It is supposed to trigger a light when there is a pressure difference felt in the system.
Old May 18, 2005 | 03:33 PM
well it looks like u was right... and it was leaking, jus never noticed it.. gotta go find one at the junk yard tomorrow
Old May 18, 2005 | 05:27 PM
Let me know how you make out after you install it.
bydand
2001-2013 model year XC70
47
Aug 4, 2025 04:52 PM
MntnDewMan
Apr 3, 2024 04:05 PM
brettboze
Mar 26, 2012 06:25 PM
STREETFIGHTER50
Mar 12, 2009 07:29 PM
VladicRavich
May 7, 2008 12:40 PM
