No clutch on my A/C compressor
Old May 28, 2015 | 08:40 PM
Czakky's Avatar
Default No clutch on my A/C compressor
My "new to me" 86' 240 has been switched over to R134. When I put my gauges on the system is reading around 70psi "static". Jumper what I believe is the low pressure switch on the filter dryer w/ sight glass.... Nothing wait... still nothing.
Is there a way to check the voltage at the clutch solenoid, with the car not running?
Not much room for my hands in there.
This is all a little embarrassing since I am an A/C repair guy by trade
Old May 28, 2015 | 08:51 PM
fochs's Avatar
Fuse 12?
Old May 28, 2015 | 09:04 PM
Czakky's Avatar
Fuses are all good and clean... Good point though.
Old May 28, 2015 | 09:30 PM
fochs's Avatar
A/C time delay relay is just inside the center console just behind the passenger side inner kick panel. Just don't know anything about this otherwise.
Old May 28, 2015 | 10:01 PM
Czakky's Avatar
Of course I would like to check to see if my solenoid is getting power before tearing up the dash... Oh well no big deal I'll see what I find
Old May 28, 2015 | 11:29 PM
Check out Volvo Wiring Diagrams you should be able to trace the wires and even colors.
Old May 28, 2015 | 11:40 PM
fochs's Avatar
If you are referring to the relay location, it's really just taking off the kick panel and reaching behind the passenger side of the center console. The relay is located behind the 2 fasteners that hold the inside kick panel on.
It looked to me in my manual like the compressor solenoid is the last connection in the system immediately preceded by the switch you were shorting. I don't see where else one could test it.
Old May 28, 2015 | 11:55 PM
fochs's Avatar
Never thought I'd send a link from justanswer, but here goes.
http://www.justanswer.com/volvo/3o02...html#re.v/181/
Doesn't address your problem, but I think gives a good peripheral view of the system and the electrical signal flow.
Old May 30, 2015 | 06:06 PM
Czakky's Avatar
Originally Posted by fochs
Fuse 12?
Ding!
I THOUGHT the fuses were all good and clean.... Maybe when I was checking #12 I broke it... Anyway clutch is actuating now, compressor sounds like a box of rocks. Looks like it's time for a vacuum and some oil... And a miracle!
Old May 30, 2015 | 06:39 PM
fochs's Avatar
Cool!
Old Jun 1, 2015 | 04:52 AM
Czakky's Avatar
So I put my gauges on and looks like there may be a blockage on the high side. Looks like I'm replacing the filter drier. Unless there is another common blockage point, I can't see that condensing coil as getting blocked. So it's probably time for a new compressor too.
Old Jun 14, 2015 | 06:59 AM
Czakky's Avatar
Fixed leak, did the pump down etc. Added new charge w/oil, now it sounds like the compressor is gonna go. Bummer...
Old Jun 14, 2015 | 09:12 AM
jagtoes's Avatar
Did you replace the orifice valve?
tech
Jul 13, 2017 12:43 PM
volksnut
Aug 5, 2007 01:52 PM
hxcboatcaptain
Sep 8, 2006 02:16 PM
mrbyrd
May 31, 2006 09:43 PM
camera cart
Jun 3, 2005 03:45 PM
