No rear defrost after overdrive bypass
Old Dec 14, 2015 | 06:37 PM
Pugluvr's Avatar
Default No rear defrost after overdrive bypass
1990 240DL Wagon (automatic)
184k
My overdrive solenoid was sticky so I had my repair shop remove the solenoid and install a bypass plate this summer. Now that the weather is turning a bit chilly, I tried to use my rear window defrost but it does not heat. The spring-loaded dash switch for the rear defrost, which illuminates when the defroster is on, does not illuminate. I see that the overdrive and the rear defrost are the only items on one fuse. I have verified that the fuse is intact and that there is power across the fuse. When I engage the gear-selector overdrive lockout switch, the dashboard arrow illuminates. All other functions at the rear door work (rear wiper, rear washer, and all lights).
What should I do next?
Old Dec 14, 2015 | 11:30 PM
check the wires where they go through the hatch hinges.
jjlrrw
Dec 13, 2015 11:22 PM
evanernest
Feb 4, 2015 12:16 PM
janeofdrama
Mar 30, 2009 10:47 PM
mattdp79
Apr 16, 2008 06:56 PM
960Tuck
Nov 14, 2006 04:14 PM
