Noisy Transmission
Old May 6, 2016 | 08:27 PM
lyonsfin's Avatar
Default Noisy Transmission
We have a manual 1980 244 with OD. The OD has never worked. Recently there has been a horrible noise coming from the transmission. It shifts and drives fine, just very noisy. One time the car began to shake and smoke came up through shifter tunnel. After stopping and starting again, it was fine, just very noisy still. I had a mechanic check it and he said that there is internal bearing failure inside the OD. Anyone have any experience?
Old May 9, 2016 | 02:45 AM
you've neglected maintenance on your 35 year old overdrive transmission and its finally breaking down., and you're asking us whats wrong??
Old May 9, 2016 | 09:26 AM
firebirdparts's Avatar
A bad bearing would be noisy. In general, though, when a transmission makes a horrible noise, you would expect to have to take it all apart to fix it. So you'll see what's wrong with it then. Not much need for diagnosis.
Old May 10, 2016 | 09:31 PM
lev's Avatar
lev
Is there any fluid in the tranny? That MAY be the reason but probably not... Too far gone most likely.
MikeySq
Dec 7, 2012 07:47 PM
dcox612
Feb 21, 2006 09:04 PM
spinningcain
Feb 2, 2006 01:17 PM
meerkat
Aug 16, 2005 01:07 AM
05s40
Mar 10, 2005 11:40 AM
