Oil Leak From Filter?
Old Nov 17, 2007 | 11:41 AM
colgate41's Avatar
Default Oil Leak From Filter?
1991 740 Turbo.
I change my own oil every 2500 miles or sooner and every few oil changes i see that there was not a lot of oil in my car. Today when i drained it i had about 2-3 quarts of oil in it. I always put 5 quarts in. The pan looks good and the only place i see oil really is where the oil filter goes on. Seems like it drips from there. Now i dont overtighten it ever but maybe the oil filter im useing isent exactly right? I have been useing purolator. Maybe its not an exact fit? I know Volvos are picky as hell at times. Maybe i should just switch to a MANN filter? Any ideas? Thanks.
Old Nov 17, 2007 | 11:42 AM
Default RE: Oil Leak From Filter?
Does your filter screw towards the front of the car?
The oil cooler might be leaking where it bolts to the block.
Old Nov 17, 2007 | 11:57 AM
colgate41's Avatar
Um, it screws towards the passenger side, its near the passenger side front wheel. im not sure really.
Old Nov 17, 2007 | 12:06 PM
But does it screw right into the block or into an aluminum housing?
Old Nov 17, 2007 | 02:02 PM
colgate41's Avatar
I am pretty sure its an aluminum housing.
Old Nov 17, 2007 | 02:45 PM
Then the seal between the aluminum housing and the block might be leaking.
Old Nov 17, 2007 | 03:22 PM
colgate41's Avatar
That is the problem most likley. Easy fix? Is it a common seal?
Old Nov 17, 2007 | 03:37 PM
Somewhat common.
Pretty easy to replace as well. Hardest part is finding a socket to fit the big bolt.
Old Nov 17, 2007 | 03:53 PM
colgate41's Avatar
Ok thanks a lot tech this helps out a bunch. What is that seal called or gasket called if i was to go searching online for a new one? Thanks again!
Old Nov 17, 2007 | 04:18 PM
Oil cooler to block o-ring.
If you can't find anything let me know I will look up the OEM part # for you.
Old Nov 17, 2007 | 05:12 PM
colgate41's Avatar
Thanks a lot tech, i am having a hard time finding it. If you could id like the OEM part # Thanks a lot!
Old Nov 17, 2007 | 06:50 PM
I would replace #4 and also replace #16.
740turbowag
Jan 29, 2015 07:41 PM
ROBLU540
Feb 20, 2009 07:59 PM
TIPSP
Feb 2, 2009 09:30 PM
jjincbus
Nov 5, 2008 03:07 AM
ptaylor01
Dec 2, 2007 12:23 PM
