oil weight recommendation
Old Oct 12, 2011 | 09:45 PM
brickrunner's Avatar
Default oil weight recommendation
I would like to know which is the ideal oil weight for a Volvo 940 in florida were it is always hot and cold spells aren't longer than a couple of days, thanks.
Old Oct 12, 2011 | 11:06 PM
swiftjustice44's Avatar
I live in Texas and run 20W-50 except in the dead of summer when I run 30W. If your car is a turbo, 10W-30 may be better.
Old Oct 12, 2011 | 11:12 PM
My car is non turbo and thanks for the help swift.
Old Oct 13, 2011 | 12:30 AM
lev's Avatar
lev
10-30, like it says in the manual
Old Oct 13, 2011 | 07:40 PM
Joseph/TX's Avatar
The manual also recommends 15w40 for hot weather/severe driving conditions. 15w40 is pretty much the standard issue for class 8 diesel trucks like my old Freightliner, which held 10 gallons of the stuff. I use Mobil Delvac in my turbo, since the engine hasn't been rebuilt yet and does use some oil. Shell Rotella is good, too. If I have an engine that doesn't leak or otherwise consume oil, I use synthetic only; right now I'm running Royal Purple 10/30 in my 240. I have heard people say that you can't run truck oil in a car because the formulation and/or the additives are "different", but I have been doing it for years with no problems/sludge/etc. whatever.
Most big truck diesel engines these days are turbocharged, so it's certainly not going to affect the turbo and besides that it says on the label that it meets the applicable standard for gasoline engines as well.
Old Oct 13, 2011 | 07:48 PM
I think all that noise about not running diesel truck oil in cars is based in the higher zinc levels still in diesel oils. They essentially eliminated it in passenger car oils to extend catalytic converter lifespans. I run Rotella T in my 140...it has a flat tappet cam and needs the zinc to reduce wear.
Old Oct 13, 2011 | 10:45 PM
Thanks for the Rotella t 15w40 recommendation. I already use that in my gas truck so I will probably start using that in the Volvo as well. It will keep things simpler.
Old Oct 14, 2011 | 08:14 AM
volvoguy2323's Avatar
Banned
20w 50.....unless it gets really really cold then 10w 40.../30. We run 20w 50 in Seattle...
Old Oct 14, 2011 | 08:15 AM
Banned
Nope...sorry lev....20w 50
Old Oct 14, 2011 | 10:46 AM
lev's Avatar
lev
May be your '88 uses 20-50, 1994 940's use 10-30 according to the Volvo manual (1994 940 Page 8:6).
Old Oct 14, 2011 | 12:36 PM
bubba240's Avatar
Correct (depending on the temp range).
MEWEAVER
Nov 5, 2013 11:17 AM
1995Volvo850
Oct 6, 2013 09:21 PM
carlsson
Mar 7, 2013 06:44 PM
xcnet180
Jun 19, 2010 05:26 PM
bryan200sx
Jun 10, 2005 03:00 PM
