Overdive not engaging
Old Sep 29, 2009 | 07:18 PM
  #21
jerryg951's Avatar
if you pull off the overdrive selonoid and gring a channell form the two holes inside the depth of the inner o-ring you will have a hydrolic overdrive instead of electric i just finished this and it works great and no need to deal with any electrical problems i got the part from a pick-a-part place for $5 spent a hour and no more waiting for overdrive
Old Sep 30, 2009 | 09:39 PM
  #22
Fresheadies's Avatar
Jerryg951, do you mind being more specific please? I was finally able to get a hold of the soldering iron about an hour ago. Unfortunately I need to be up early for a busy day tomorrow and night.
In the same vein, I opened up the plastic cover of the center console but was unable to remove the shifter **** to expose the OD wires on the shifter to test if the OD button itself was to blame. I remove the small plastic lock on the bottom but the **** was still on tight. Can anyone help?
Old Oct 2, 2009 | 10:54 AM
  #23
bubba240's Avatar
This is basically what he is saying:
http://www.ipdusa.com/Volvo-200/Tran...-266-672-1891/
But you can cut this channel yourself using your old solenoid. But you will no longer be able to lock-out OD.
Old Oct 26, 2009 | 12:31 PM
  #24
Do you think that the above mentioned product would fit into my vehicle? I really have no need to turn off the Overdrive. I drive a wonderful 1992 940GL 8-valve.
Old Oct 27, 2009 | 02:04 PM
  #25
bubba240's Avatar
The IPD plate is for the AW70/71 transmissions (Aisin Warner). Thats most likely what is in your 940, but you'll want to look at the label (driver's side) to be sure.
The AW/70 plates I have seen say "03-70" printed on them.
Old Oct 28, 2009 | 11:40 AM
  #26
jpirish's Avatar
FYI
I had the same problem with my 91 240.I replaced the motor mounts and the trans. mount.And YAHOO the problem went away.
The trans. mount was the worst of them all.My shifter was shaking side to side when I would hit a bump in the road.
I hope this info. helps.
jpirish
Old Nov 9, 2009 | 02:15 PM
  #27
ALRIGHT, I was finally able to procure a jack and the when I checked the transmission..... No ID plate! Great! I can identify where it's supposed to be but it's not there... Interesting... Anyway, I remember my old Chilton's said the B230F engine has a AW70/71 tranny. I'm going to go ahead and order the part. I live in Maine so I'd rather get this done before the cold winter sets in!
Regarding the mounts. My engine mounts are A-OK but the tranny mounts are definitely on their way out. My shifter also shakes during operation most of the time. Is the the tranny mount a one man job or will I have to lower the tranny completely?
Thanks guys
Old Nov 9, 2009 | 05:10 PM
  #28
blue goose's Avatar
No need to drop the tranny when replacing the mount. But you need to remove the tranny cross member, which is the supporting beam. Put the front of the car on ramps or jack stands. Support the tranny with a floor jack then remove the cross member. Should be two bolts on each side.
Old Nov 11, 2009 | 08:08 PM
  #29
john1990's Avatar
does it have a over drive button? on the older models the button was on the shifter and the wire would break.you would have to remove the console,the wire came out at the bottom on the shifter usually where it broke. not sue onnewer modles only owned 90 an
Old Nov 12, 2009 | 10:54 PM
  #30
Yes, it has an OD button on the shifter. I was able to remove the console but not the shifter ****. Any advice on how to do this? I own a 1992 940 GL 8-Valve.
Old Nov 21, 2009 | 01:44 PM
  #31
regime's Avatar
Hey all,
I'm suffering from the same issues right now. Finally crawled under the car to look and the white wire that leads to the OD Solenoid wire is all kinds of cracked...
Not to hijack the thread, but does anyone know if someone sells just the wire that leads from the sifter inside the car to underneath?
Thanks
Old Dec 2, 2009 | 04:00 PM
  #32
regime's Avatar
I got my flexy 12mm ratcheting wrench on black friday from craftsman.
I got my overdrive block of plate today from IPD
And now I'm well on my way to rounding out the 2 bolts holding on the freakin' solenoid... This wasn't completed because the wrench fell apart first...
Does any one know what the size of the bolts are so i can go get a couple of replacements for them???
Old Dec 3, 2009 | 11:28 PM
  #33
karajan's Avatar
I had to trace the wires leading to the OD component of the transmission. Sure enough, the wires were cut from wear and tear over the years. I simply reconnected them and the OD works just fine.
firepop5
Jul 2, 2010 01:57 PM
monkeyworkz
Aug 13, 2009 10:16 AM
sblaine
Feb 9, 2009 12:03 PM
png
Dec 19, 2008 01:17 PM
