Please Help. Volvo 240 Passenger Side Brake Light Won't Work.
#22
The scorch mark means it is getting a poor connection and overheating. To solve these sort of issues I removed the metal teeth from the connector and used a needle nose pliers to bend them so they grab the edge connector of the tail light better. This was a more permanent solution than the dielectric grease for me.
This seems to be the problem. Getting really tired of cleaning off, and then reapplying the di-grease multiple times until it finally works, only to stop working a day or two later. I don't see how to pry these up without doing damage. Any suggestions on a permanent solution?
#23
Maybe try a paper clip to use as a tool to bend connector? I have a 4 pc pick set I would try, you get them at any place that sells tools/hardware...Home Depot, probably auto parts store. Or maybe go to a boneyard and get a connector and splice in? If you can find one in your yard...they are hard to find now-a-days.
#24
GeertMeijer
03-25-2010 01:55 AM
vlvonewp
10-13-2009 06:52 PM
