PLEASE NEED HELP on non start problem (no spark) 940
Old Oct 26, 2012 | 07:19 PM
jelarf's Avatar
Default PLEASE NEED HELP on non start problem (no spark) 940
Well here I sit with my 1993 940...it was running fine I had just done head water pump belts timing belt and new radiator...the radiator I had received was incorrect and plastic...so I ordered a new one OEM it arrived today...so before it was delivered, I had removed the old/new (that I was replacing) one and did a clean out with water of engine...I should say here car was running fine (I did have some questions about re torquing head)...the one problem I was having was that the fuel gauge was giving me problems work one day then crap out the next (dead)...so while I was waiting for the new oem radiator to arrive (FedEx) I opened the trunk and went into the fuel pump hatch...to see if there were any loose wires..Non...then pulled the drivers side trunk panel and checked the wires no problem there..so I looked under the hood no problem looked at fuses no problem...in the mean time the radiator arrived...and I installed it...then went to start car...turned over but no start, could smell fuel after a few trys...pulled # 1 plug and non spark, but sorta wet with gas and smells like gas...checked everything just can't figure this out...I just sold our other car...and now this for a few weeks is our main car...any ideas as to what the hell I did! it is a 940-non turbo...lot of miles but good compression...I really need some ideas here
Old Oct 27, 2012 | 05:15 PM
lev's Avatar
lev
Very hard to diagnose after having changed so many parts... Obviously something did not get put back together right. Recheck your work!
Old Oct 29, 2012 | 09:37 AM
act1292's Avatar
Sounds like you need to diagnose the ingition system as you don't seem to be getting spark. Try this web site and look at the section for diagnosing no-start conditions:
Home
Good luck
DecalService
Dec 4, 2019 10:52 PM
Volvo 940Dan
Oct 27, 2012 05:27 PM
volvoQ's
Apr 23, 2011 10:00 PM
Sanel30
Feb 18, 2010 09:16 PM
joker834
Nov 15, 2006 10:15 PM
