Popping Rear End
Old Jul 17, 2011 | 12:53 AM
Albi the Swedish Dragon's Avatar
Exclamation Popping Rear End
So I recently had the clutch replaced in my '91 240. Not long since then, during a spirited shift, I'll hear a pop that sounds like it is coming from either the u-joint or the differential. The thing is that the driveshaft was not removed during the procedure. The guy just disconnected the driveshaft from the transmission then dropped the tranny to get to the clutch. What is going on back there?
Old Jul 17, 2011 | 03:34 AM
dezertsub's Avatar
Get under there while the car is securely on jackstands, in park, and grab the shaft with two hands and try to get it to rotate. If there is any play at all, inspect your u joints, and if they are at all worn replace em. Make sure everything is snug, wouldn't hurt to try and tighten u joint bolts while down there, but don't go crazy over tightening them.
Or maybe you're just not very good at quick shifts...
Good luck and let us know.
Old Jul 17, 2011 | 07:03 PM
Typhoon's Avatar
I'd look at suspension bushes, particularly the torque link bushes next to the differential housing.
grosseile88
Sep 10, 2011 11:29 AM
grosseile88
Jun 9, 2009 10:01 PM
grosseile88
Apr 10, 2009 11:58 AM
Bruno937
Mar 8, 2009 12:41 PM
sherwei
Oct 26, 2007 11:34 PM
