Power window regulator question
Old Aug 3, 2020 | 02:38 PM
Pugluvr's Avatar
Default Power window regulator question
1990 Volvo 245DL 222k miles
Question about the power window regulator motor: The motor has a red and black wire going to it. Am I correct in the assumption that the motor gets its ground from being mounted to the steel regulator that is mounted to the car door, and the motor will spin one way if the red wire gets 12V and spin the other way if the black gets 12V? I have the schematic for the power windows but I am not very adept at interpreting it.
Old Aug 3, 2020 | 04:00 PM
Originally Posted by Pugluvr
the motor will spin one way if the red wire gets 12V and spin the other way if the black gets 12V?.
The switch reverses the power. So, both wires are used. Red and black need to be + and - or - and + at the same time, to go one direction or reverse. The ground does not come from the case.
Old Aug 3, 2020 | 05:18 PM
Pugluvr's Avatar
Smile
Yeah, that makes sense. Thanks.
Pugluvr
Oct 24, 2020 07:05 PM
HoopyFrood
Jun 3, 2015 10:28 AM
Auburntig55
Oct 24, 2012 08:16 PM
John Clawson
Oct 24, 2012 05:56 PM
JO7
Mar 21, 2008 09:07 PM
