Preferred T Fluid change method
Old Mar 17, 2008 | 12:14 PM
daver80's Avatar
Default Preferred T Fluid change method
89 240DL- I read a post months ago about how to do a transmission fluid change up by the radiator. Is that a preferred method of all you Brickheads? My manual says to disconnect a pipe (yikes) and drop the pan. Disconnecting pipes makes me a bit nervous- it dosent leakright now...Anyone? Dave
Old Mar 17, 2008 | 01:46 PM
gforce's Avatar
Default RE: Preferred T Fluid change method
Dave, If you pull the return line to the trans. you will be able to change all the fluid in the trans. but it is much easier with 2 people since you have to refill as fluid is pumped out. If you pull the drain plug in the trans pan you will change 2.5 quarts. The only way to get the fluid out of the torque converter is with the return line.
Old Mar 17, 2008 | 03:08 PM
daver80's Avatar
GForce- thanks again for your help with my idling issue. Could you clarify your responce here? Where is the return line? Dave
Old Mar 17, 2008 | 04:02 PM
blue goose's Avatar
My former neighbor Dave Shannon posted the procedure.
http://volvo2.homestead.com/aw70.html
Old Mar 17, 2008 | 04:34 PM
daver80's Avatar
Terriffic! Thanks all!
MnHornet
Apr 9, 2014 05:41 PM
liweih21
Jun 5, 2013 04:40 PM
chuckketcham
Oct 24, 2012 09:52 PM
reidb1
Jul 8, 2008 01:25 PM
jguerra3235
Mar 25, 2007 10:20 AM
