press fit bushings
Old Jul 15, 2009 | 01:41 PM
brf0007's Avatar
Default press fit bushings
Does anyone know if a 6 ton press is enough to press fit the bushings into the control arms?
Thanks
Old Jul 16, 2009 | 05:05 AM
Typhoon's Avatar
Should be plenty. Be sure to back up the control arms well when pressing in.
I usually just whack em in with a block of wood and a mallet, they don't need that much force.
Regards, Andrew.
Old Jul 19, 2009 | 07:47 AM
Beardog's Avatar
should be more then enough. I bet you could probably do it on an arbor press with a bit of Ruglyde or some other lubricant. ANyway, the more tons, the easier it is, but the more likely you will crush something when you don't want to.
87 740 turbo wagon
Feb 20, 2014 08:50 PM
Platinum52
Jul 17, 2009 07:33 PM
Volvo240guy
Jul 30, 2006 03:28 PM
pawel
Jul 18, 2006 12:26 AM
harveydave
Aug 16, 2005 12:36 AM
