Puzzling No-Start 1987 740 turbo
Old Aug 28, 2014 | 08:18 PM
  #21
Nothing in there should be making any noise, the ECU is purely electronic. its a circuit board, with an Intel 8039(*) 8 bit microcontroller chip, with various input/output circuits for the sensors and actuators (power transistors for the injectors and various relays the ECU controls, a/d converters for the ECT and AMM.
(*) the LH2.2 ECU has a 8039 processor, which is an 8048 with no ROM and more RAM. the LH2.4 ECU is a faster 8051 family CPU, and a very similar board.
typical LH2.x boards (these are from a porsche 928 but are nearly the same as the Volvos)
Old Aug 30, 2014 | 11:31 PM
  #22
fredbyte's Avatar
Default found source of noise
You are, of course, right, Pierce. Thanks. I finally found the source of the noise by using a stethoscope. It's coming from a black, cylindrical object forward/above the ECU. The cylinder is about 3" in diameter and ~ 2.5" high. Could this be a climate control fan? I'll try to post a photo.
Old Aug 31, 2014 | 03:07 AM
  #23
740 ventilation, with the glovebox removed. not mine, I cribbed this photo from somewhere.
the drum on the far right is the fan cage, the fan motor is installed from below. the thing to the left is the AC evaporator, then the heater core is in the center console, with all the air ducting coming off it.
if you turn your AC off and switch your fan to 0, it /should/ be off. theres' a lot of vacuum controls of all the air flaps, you could be hearing a vacuum leak, I suppose. The flap for recirculating vs fresh air is right above the fan.
Old Aug 31, 2014 | 10:27 AM
  #24
fredbyte's Avatar
Thanks, Pierce. I don't see my little, black cylinder in your photo. It should be forward/above the ECU and to the right of the big gray drum. Any idea of what my little black cylinder is?
Old Aug 31, 2014 | 06:57 PM
  #25
without seeing it, I'm having trouble guessing.
Old Aug 31, 2014 | 11:11 PM
  #26
fredbyte's Avatar
It was the blower motor/fan. The small black cylinder was the actual motor assembly sticking down. Thanks.
TSPowell
Aug 9, 2015 07:11 PM
jozer
Apr 25, 2013 05:01 AM
gedaggett
Feb 11, 2013 07:34 PM
gedaggett
Jan 30, 2013 11:59 PM
TheVolvoMan
Feb 13, 2007 02:55 PM
