Quirky stuttering
Old Apr 30, 2008 | 07:37 PM
tkeser's Avatar
Default Quirky stuttering
Out of the blue my 1986 245 (333340 miles) has started stuttering randomly. While driving at cruising speed the tachometer will jump up to like 2K and drops to 500 or even 0. It feels like the motor stops briefly for a split second. Sometimes this occurs once, other times it will occur three or more times in a row. I noticed too that the temp gauge is zeroed out too. I am not sure if I am having electrical problems, fuel problems or something else. I have recently replaced the plugs, rotor,cap, plug/coil wires, fuel pumps, and timing belt just as routine maintenance. Any ideas?
Thanks
Old Apr 30, 2008 | 11:24 PM
jonesg's Avatar
Default RE: Quirky stuttering
The tach is the clue that its ignition/elec , not fuel delivery.
The tach indicates ignition, if it drops to zero whilst the engine is still rotating the ignition is dead, if the tach dropped slowly with engine rpm it would be fuel.
Coil ground can be a problem.
Old May 1, 2008 | 06:45 AM
tkeser's Avatar
Thanks! Which terminal is used for ground?
tom98s70
Mar 7, 2012 10:47 AM
volvochick245
Jun 28, 2011 09:51 PM
geigy
Jan 10, 2010 04:23 PM
kirkgrau
Sep 8, 2009 01:16 PM
BRANSTONE
Aug 25, 2008 03:54 PM
