Radio: right speaker channel intermittent
Old Apr 3, 2005 | 11:18 AM
Carbuff's Avatar
Default Radio: right speaker channel intermittent
The factory radio (model CR 814) on my 940 has what may be a dirty volume control. The right hand speakers don't work unless I jiggle the ****. Works when "cranked" at high volumes (but then my ears hurt!).
My question is, is it worth my time to try and fix this? I plan to squirt some electronics contact cleaner behind the **** as a first effort.
How is the **** removed? I tried pulling but haven't given it a lot of force for fear of breaking something. Don't see a setscrew.
Are there instructions for radio removal somewhere on the 'net?
TIA
Atwell Haines
94 940 Wagon
NJ
Old Apr 3, 2005 | 01:54 PM
Default RE: Radio: right speaker channel intermittent
The **** should just pull off.Yes it might be tight but it is just pushed on.The trim panel that goes from around the radio to the steering column should come off the access the screws to remove the radio.
Yes a dirty volume switch will cause that to happen.
banamexdf
Jul 12, 2010 07:57 PM
Scott Baret
Oct 31, 2009 06:53 PM
AMoore
Sep 2, 2009 07:09 PM
nottacop
Jan 10, 2007 10:43 AM
jdhore1
Jul 4, 2006 05:41 AM
