Rear Brake thingy
Old Nov 15, 2007 | 08:42 AM
act1292's Avatar
Default Rear Brake thingy
Bolted to the underneath of the car is a thingy that the steel brake lines coming from the front of the car enter and the flexible rubber brake lines exit. What is this thing? Can I transplant one froma 240 wagon to a sedan?
The reason I am asking is that I cannot get the flexible lines out of this thingy on the sedan due to major rust. I have a good set taken from a wagon that isn't rusty at all. I can get the steel brake lines out so I was thinking of swapping the units.
Old Nov 15, 2007 | 05:21 PM
funnyguy44444's Avatar
Default RE: Rear Brake thingy
They should be compleatly interchangeable. The only difference between the wagon and the sedan is well, the back end of the body. Other than that the mechanics are all exactly the same.
Old Nov 16, 2007 | 12:32 AM
act1292's Avatar
Thanks for the info. Any idea what this thing does?
Old Nov 16, 2007 | 07:23 AM
89_240_DL_Sedan's Avatar
Old Nov 16, 2007 | 03:08 PM
Not sure really. What year is yours? My '82 has steel brake lines running all the way from the master cylinder to the calipers.
Old Nov 16, 2007 | 03:30 PM
act1292's Avatar
I have an '89 240 DL wagon and a '91 240 sedan.Both have the same assembly. The assembly has two cylindrical shaped objects - each has the steel brake line go in on one side and the flexible rubber line coming out on the other side. It's pretty clear that one cylinder handles the left side line while the other handles the right side line.
I was wondering if it had anything to do with balancing the front/back braking.
Old Nov 17, 2007 | 11:43 PM
83242GT's Avatar
they are valves that regulate the weird but amazing braking powers of the 240s. as you may know240s have 2 aux. braking systems (thats why so many bleeder screws on the calipers) they regulate pressures between both systems, if one should fail those valves keep the pressure from being in excess causing lock up...(cave-man type ABS) basicly. so in affect yes it does deal with balancing of the braking system.
Old Nov 18, 2007 | 07:21 PM
act1292's Avatar
I suspected something of the sort. Thanks for the information.
nuclearseal
Feb 26, 2013 09:55 PM
gilber33
Jun 3, 2010 01:59 PM
shelbylay
Engine & Internal
Nov 7, 2007 09:05 PM
adub96
Nov 19, 2006 07:18 PM
dcc70
Sep 13, 2006 08:30 PM
