Rear end noise 93 240
Old Apr 5, 2022 | 08:49 AM
depgoody's Avatar
Default Rear end noise 93 240
I recently changed out the rear trailing arm bushings to polyurethane ones. Since then I have whining and howling noises when I accelerate and decelerate above 40 mph. Sounds like rear diff noise. I then pulled the driveshaft and replaced the center bearing and loose u joint near the diff. Still getting the noise. Never had the noise until changing bushings. Related to poly bushings somehow it seems. Anyone experience this? Vehicle has 191k miles and runs strong.
Old Apr 5, 2022 | 10:13 AM
lev's Avatar
lev
They are stiffer, so less dampening, transmit more noises and vibration.May have had the noise before, now it's more pronounced? Did you check the fluid in the diff?
Old Apr 5, 2022 | 05:11 PM
depgoody's Avatar
Lev I do not recall any noise like that before. But the poly bushings may be somewhat of a culprit. I will have the diff. fluid level checked. There are no leaks but will check anyway. Thanks for your quick response.
Old Apr 5, 2022 | 09:35 PM
Simple solution - car was quiet, someone put in weird aftermarket parts, now there is noise. Put real parts in and see if the noise goes away. There are many posts about the cool poly bushings being noisy everywhere they are placed. Pretty blue color (usually) but many complaints of transferred vibration/noise.
If poly was better - why don't any car manufacturers use them?
Old Apr 5, 2022 | 10:47 PM
depgoody's Avatar
I wish I had known about potential problems with the poly bushings. Spent good bucks to get them installed. But you are right. I need to to put new rubber ones in and see what happens. Will check diff fluid level first though. Will let you guys know. Thanks.
autotech30
2001-2013 model year V70
May 11, 2012 09:41 AM
bubba240
Oct 28, 2011 01:04 PM
family XC70
May 1, 2010 06:48 PM
rae8525
Jul 25, 2009 08:28 AM
Red XC
Suspension
Oct 22, 2005 11:58 AM
