Rear suspension 1988 to 244
Old Aug 17, 2019 | 02:15 PM
lionhearted1's Avatar
Default Rear suspension 1988 to 244
Just bought a very nice 1988 to 244 previous owner replaced coils and shocks to heavy duty and it rides way too stiff. Like a buck board. Sometimes it feels like it bottoms out in the rear. Can I replace the shocks with a softer shock will it help at all. I really do not want to get into replacing the coils again. Shocks that are in it now are racing shocks and are very very stiff. Thank you, Richard
Old Aug 18, 2019 | 06:29 PM
shocks ideally are matched to the springs. stronger spring requires more damping (aka stiffer shock).
but stiffer suspension shouldn't be bottoming out.
anyways, assuming the replacement springs are NOT lowering springs, AND they didn't install some crazy coilover racing suspension kit, you should be able to use the Bilstein Touring shocks, whatever those are called now, and get a softer ride.... the only way to return it entirely to stock would be to replace the springs, too.
rear shocks are pretty easy to replace, front shocks are mcpherson struts inside the spring, not so easy.
front strut inserts, https://www.fcpeuro.com/products/vol...65-240-touring
rear shocks, https://www.fcpeuro.com/products/vol...65-240-touring
twe
Aug 29, 2018 07:04 PM
240-FAN
Aug 14, 2018 03:17 PM
Phil 850
May 16, 2018 08:09 PM
zjinqui1k
Nov 12, 2015 04:41 PM
Richard Lane
2001-2013 model year V70
Apr 17, 2014 02:23 PM
