Rebuilding 1992 NA B230F RedBlock
Old Mar 13, 2016 | 11:22 AM
xDread92x's Avatar
Default Rebuilding 1992 NA B230F RedBlock
Hi All,
So I posted a while back about my 92 NA 240 that was ran without oil and the engine seized up. I got the engine unseized and immediately after there was a knock on decerlation and in some cases at idle. NOT while on accleration though. At this point I figured I would just drive it until it was done. The day it stopped running I assumed the worst but I believe now what actually caused the stopping of the engine was a bad alternator. Anyway, I bought another 244 immediately after and its been in the yard for about a year.
NEXT, I was told if a rod blew that it would be cinematically poking through the block somewhere, etc. I examined my block and see nothing of the sort. I am beginning to believe what the block acquired was a piston slap. Anyway, I am now in the beginning stages of building a turbo brick and just my luck there are no redblocks in the nearest junkyards. So while I have this block sitting in my yard of course it could probably live being used but I am not really feeling having a noisy block. So can I rebuild this? I can't find anything online about someone rebuilding these. Is there a reason for this?
Thanks
Old Mar 13, 2016 | 03:46 PM
lev's Avatar
lev
Rebuilding an engine is a major undertaking. My advice is, if you are looking for instructions, DON'T! It will cost a fortune and the result will be underwhelming (I am being kind)... You can buy a b230 for a couple of hundred in most markets--that's the way to go!
Old Mar 13, 2016 | 10:10 PM
xDread92x's Avatar
I really don't need an entire engine. Just a block. I have everything else. The block is really the foundation and I can't start my project until I have one. I have checked local JY's and there are no 2/7/900's. I have checked ebay and craigslist but im not trying to buy a whole car either. Some are for sale for 700-1000 bucks but I just don't need all of that. Any other ideas of where I could locate a redblock?
Old Mar 13, 2016 | 11:02 PM
um, if your engine siezed up, odds are the crankshaft bearing surfaces are scored, the rods and pistons damaged, the head, everything.
Old Mar 14, 2016 | 10:06 AM
lev's Avatar
lev
Nobody will sell you "just a block". And even if you did find a block somewhere, how would you know if the block is OK? It means that someone has a block from a good engine they stripped--that's a lot of work! You are better off buying an entire motor. If you insist on true rebuilding, you will be shocked at the a la cart prices of things like pistons, rings, rods, etc. That is, if you can even find them.
Old Mar 14, 2016 | 11:15 AM
xDread92x's Avatar
I would like to think the head is still OK. That's really what I need off the car. The block I could care less about. I just got the head machined also when I replaced the head gasket. It cleaned up real nice. The car still ran like a boss after the seizing. When I take head off will there be any noticeable damages? Busted valves, any discolorations, etc?
Thanks
Old Mar 14, 2016 | 03:30 PM
Bigryan86's Avatar
You might beable to find just a block from an engine builder. Or just take in your block and have it bored and honed.
xDread92x
Jan 7, 2018 05:20 PM
240-FAN
Jun 11, 2014 06:12 AM
c4rpe_d1em
Mar 22, 2011 09:58 AM
mountain lion
Feb 17, 2011 11:24 AM
andy89
Engine & Internal
Jan 25, 2011 07:51 PM
