removing an 87 240 clutch slave cylinder
Old Sep 18, 2010 | 05:59 AM
mark mustang's Avatar
Default removing an 87 240 clutch slave cylinder
Is removing the slave cylinder an 1987 model 240 simply a matter of removing the flexible fluid hose and a circlip on the rear end of the slvae cylinder.
Old Apr 18, 2011 | 09:38 PM
jnco666's Avatar
i might be having a slave cylinder problem... what problem did you have??? so i would know if its that or not.
Old Apr 19, 2011 | 06:28 PM
Default 240 slave cylinder
the seals in the slave cylinder went on my car. If this happens, you will leak clutch fluid. If your slave cylinder is completely broken, you will have no pressure on the clutch. check your clutch fluid to see if it is leaking
mpower916
Nov 24, 2013 02:38 AM
Too Tall
Aug 1, 2013 05:20 AM
u_ruse
Nov 8, 2010 09:09 PM
seaniolaytham
Sep 21, 2009 10:53 PM
fredbyte
Jul 28, 2009 02:47 PM
